Results 1 to 9 of 9
    Default Aluminum driveshaft
    Thinking about getting a ford racing aluminum Driveshaft for my 82 gt. Any input or suggestions.thanks
    Less rotating mass is a great thing. Especially if you have steeper (numerically higher) rear gears.
    Most of our cars have many miles which means the slip yoke on our driveshafts are well past their prime. Your tail shaft bushing in your transmission will thank you!
    Great time to use the special tool to put in a new bushing along with a seal.
    Do it! Share your experience!
    I installed one back when they were $159 because I was too lazy to have the U-joints swapped and since they were 20 years old (at the time) I figured they could stand to be replaced. There was absolutely on change whatsoever that any human could notice in how it drove but sure, it's less rotating mass so how can that not be a good thing?
    John Adams
    July 7, 1775
    Thanks.ok next question i was going to replace the tailseal bushing and seal . any recommendations on a removal tool for the bushing.
    The only problem I have ever seen with aluminum driveshafts was on a lowered car they sometimes hit the floor or same goes for a driveshaft loop, you might need to adjust it to get the clearance you need. Not sure if the tailshaft bushing can be changed in the car, the output shaft might be in your way.
    1984 LX 5.0 Vert *SOLD*
    This should work:
    http://www.freedomracing.com/trans-e...FYS4wAod23gCHA
    i just made my own tool. There is a oval slot in most of them that can be caught by a straight blade screw driver heated and bent to a 90 degree on the end at the proper length. I put another 90 on the other end then clamped it to an old water pump bolt that I put a washer and an old alternator pulley on it - made a nice little slide hammer.
    I later learned there is no inner bushing stop on fox T5 tail sections. You can literally pound the old one into the trans with the new one and let it ride there until you rebuild it.
    Quote Originally Posted by FoxFords&FFR's View Post
    Good point! Mine hit the emergency brake equalizer. I had to trim just the slightest bit off it to gain clearance. That should be checked while the car is still in the air.
    John Adams
    July 7, 1775
    Was thinking about one of these. My only fear is that because they have a larger diameter, it's going to hit my exhaust or floor and drive me nuts.
    1984.5 GT 5.0 5 Speed ANALOG
    BBK Long Tubes/H pipe/FM
    Edelbrock Intake/Holley 600
    8.8 w/FMS 3.73s
    Steeda Shifter
    2010 GT 5 Speed DIGITAL
    Track Pack
    Pypes Violator axle back
    Airaid Cold Air
    For what its worth I have a close friend with a high 7 sec 1/8 mile car. As he was getting into low 8s he switched to aluminum driveshaft. He said his car slowed down. Apparently the spinning weight on a low horse car keeps it moving quicker through the gears but slower on take off. He said with the aluminum shaft he had to launch at higher rpm, car was quicker off the line but slowed down because the inertia weight of the metal spinning shaft was no longer there. It wasnt until he got to around a legitimate 300rwhp that he seen a difference. Just food for thought.
