I've read articles in the past that talk about using an aftermarket lower intake with a ported stock upper as a way to make an absolute sleeper.
I know these days a lot of guys buy 96 Explorer intakes, port the lower, and call it good. With a 5.0HO badge it's not terribly obvious but I'd like to track down the early days methods that were once used that are much harder to identify.
It seems to me back in the early days guys were porting stock lowers then cross drilling between runners to further encourage flow and cause a shorter perceived runner length too in order to eek out a little horsepower and a bit more RPM.
later attempts ground down the runner divider so it couldn't seal each port from the other then ground the dividers to a razor edge on certain aftermarket intakes
Also opening the inlet and spacer up to 65 or even 70 MM and adding a bigger throttle body.
I think the main manifold used was a Holley System Max. There may have been others too. Just trying to dig up this old info so I can capture it for reference purposes when I finally get back around to playing with making stock appearing fast.
