I took the visor off the rod, bent rod a bit. Wrapped electrical tape around rod. Put visor back on rod. Problem fixed.
Took trial and error for correct amount of tape. This was on an '85 t-top.
I think I know what you are describing. The sunvisor slides right over a rod and after time the rod wears smooth and the sunvisor wont stay in the upright position.
I fixed mine by using an electric scrib pencil I got at Harbor Freight Tools for less than 10 bucks. Like this one at Home Depot
http://www.homedepot.com/p/WEN-Varia...w&gclsrc=aw.ds
I used it to scribe ribs into the rod raising the surface and creating grippage.
I tried the slight bend of the rod trick today and it's seems to be working.
Jeremy
83 T-Top coupe
89 LX 5.0
16 PP GT
Jeremy
2016 Mustang PP GT
1989 Mustang LX 5.0
1983 Mustang L T-Top Coupe
If you're talking about the way the visor pivots up and own on the long thin rod that holds it, I'll tell you how I fixed mine. I found that even with new visors there was still play because the rod was worn from years of wear and tear. I could see the scoring in the metal. Even getting a used one might still be shot or close to it. So i bought an electric engraver from harbor Fright. A cheap one. https://www.harborfreight.com/electr...ver-46099.html
I polished the steel rod with sandpaper then I took the engraver and I scored it with lines length and width wise. It raises the metal above the surface and kind of created a spline with the engraver. At first the visor didn't want to go back on easy so I polished the "spline" gently with sandpaper, testing the fit after a few tries I was sure it was right. I smeared a thing coat of never seize on the rod and wiggled the visor back into place.
In the 5 years since I did that I have had zero flop. They stay where I place them and they are probably a little tighter than they were from the factory. but it's a problem solved permanently and I don't need an ugly magnet. There's nothing to lose by trying it.
