Looking for some input....
Picked a new crate motor from Mike a few weeks ago and would like to paint it before installing. The block & heads are bare metal with some light surface rust from sitting. New water pump, timing cover are bare aluminum and look good. Lower intake is installed (bolted on).
Was thinking about brush painting the block & heads but not sure on what type of paint to use. I think it may easier to brush it on rather than taping everything off and spray bombing it? What is available as a brush on engine paint? Would probably use a grey or black color.
What prep work is needed for the light surface rust? Can a rust neutralizer be applied over it?
Thanks,
Zen
