Results 1 to 4 of 4
    Default Sn95 brake upgrade
    I'm installing a set of 94 front and rear brakes on my 81 fairmont. I'm just wondering if I need to swap out the power brake booster and the master cylinder. I have everything else. The car was originally a 6cyl. I'm not sure if that matter or not. Thanks
    1980 Futura 347 C4
    It's recommended, it really depends on the size of the bores in your master cylinder. There's a whole site dedicated to the swap and what you need. Just Google it.
    1984.5 G.T.350 had since 16y/o
    95 Cobra, Crystal White
    Mar 2013
    Where the Navy sends me...
    Also lots of discussion here in the Wheels, Tires, Brakes & Suspension forum.
    I would recommend replacing both, not only could they be the old 30+ years original parts, but the Master Cly is not correct for a 4 wheel disk brake system.
    1985 Ford LTD LX
    1989 Mustang 5.0 Coupe
    1994 Ford F150 Lightning
