Yeah I do have pictures of more detailed items, but I leave that for specific fixes and try to post those in its Forum, such as the Exhaust, Suspension, etc., for the project, I wanted to show the actual build with out getting off track.
Funny I have always known about the Fairmont, it seemed to be almost as common as the "Pinto", but I didn't know anything about the Zephyr until I joined this Forum. It will now be something I will keep an eye out for.
1985 Ford LTD LX
1989 Mustang 5.0 Coupe
1994 Ford F150 Lightning
Engine Installed and running:
1985 Ford LTD LX
I do need to do some body work on the passenger side doors, and the black trim needs to be painted. I am just finishing up the interior, which turned out pretty nice
1985 Ford LTD LX
Had a little set back with the Fuel Pump. I had used a Fuel Pump I had used in another car, worked fine at the time, but it looks like leaving it on the shelf for a few years dried out the seals (similar to what happens to a carburetor when left sitting after running gas though it). Although I tested the Fuel pump after installing it and I could hear it engage, I wasn't able to test the actual fuel pressure until the engine was running. The engine would run fine, and was able to adjust the pressure, but once the engine was turned off, the fuel pressure drop right away.
No big deal, other then having to drop the Fuel tank again. Lucky I only had a few gallons of gas in it. This did allow me to take a few pictures of the 8.8 Rear end.
1985 Ford LTD LX
I had a Rear End sitting in storage for several years, it was setup with an Auburn with 3.55 Gears.
1985 Ford LTD LX
The Rear End cover is a copied version of the Ford Racing, but is only around $100.00 and works just fine, it just doesn't have the Ford Racing Logo.
https://www.amazon.com/Mustang-Alumi.../dp/B00D0X1MUQ
I also changed out the 4 lug Axles for 5 lug, and added the caliper brackets from Northracecars.com
1985 Ford LTD LX
That is a nice car. I know it's a Fox, but that really turns out like a 4 door Mustang with all the mods you made! Definitely not granny's grocery getter anymore!
I didn't have any problem using 87-93 Hard Brake lines, they just needed a little bit of tweaking to fit, once done it looked like the factory installed them. I could have used the old ones off of the Mustang, but since I didn't want to deal with possible leaks with old hard brake lines, and once everything is put in place, the last thing you want to deal with is replacing the hard brake lines, so I purchased the Stainless Steel lines from LMR. The other item required is the SN95 rear brake line that runs across the rear end so it connects to the Cobra Soft Lines.
1985 Ford LTD LX
I don't have any pictures of the Drive Shaft, but I used an Explorer 6 cly, 4 door type. I just changed out the U joints and the Flanges from the Mustang one and it fits and works like a Factory piece.
1985 Ford LTD LX
Using the 87-93 Fuel Injection Lines on the LTD are a different story, I first attempted to bend the old lines to fit, but it needed several bends and once done it looked like crap, so I ended up purchasing some new 5/16 and 1/4 line along with some tools to bend and cut the lines . This was a learning experience so I ended up wasting several feet, but the Tube is cheap (25 feet is around 25-30 dollars).
I did use some of the Original Fuel Injection tubing, but only to where goes under the fender and connects underneath near the sub frame, from there I used new tubing. To connect the old and new tubing together I used a "Fuel line Compression Union", which worked fine, no leak issues at all. Just make sure if you use these that they are made for fuel. This type of Compression fitting it all brass, so the fuel wont break it down and cause it to leak.
https://www.amazon.com/Dorman-800-22...n+800-222+Fuel
I may end up replacing with Stainless steel Flex line, but this works fine for now.
1985 Ford LTD LX
Interesting. I scrapped the Mustang fuel line as well and went to -6 braided stainless. I'm not sure if that's too big or what, but I've never been able to get my fuel system to work well. The fuel pressure always drains back after i shut the engine off, despite going through several fuel pumps and regulators. I'm pretty sure the problem is on the pump side, so i have yet another pump waiting to go in. I just hate pulling the gas tank. I also have a vapor pressure build-up problem. I can't pump gas into the thing without it spitting back at me. SO frustrating. I know i need to fix it; I'd rather not blow up if I can help it.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
In my case the only thing wrong was an old pump I used. Once the engine was shut off, the pressure drop right away. The new pump holds the fuel pressure for several hours after the engine is shut off, which is what it should do.
The LTD LX comes with a 20 gallon tank, and comes with the correct Vapor Valve which connects to the Vapor Canister and the fuel pump sits in the tank like the mustang. The Vapor Valve, along with the fuel return line, I believe is what keeps the fuel pressure stable, and if its not part of the fuel system this could cause problems with the pressure in the tank, but I may be wrong.
Now I just have to figure out how to get the LTD fuel sending unit to show the correct amount of fuel in the tank. Looks like one option is to modify the Mustang sending unit arm.
1985 Ford LTD LX
1985 Ford LTD LX
I did something similar converting my 85 to Holley TBI efi. I used a similar dorman product but it's a compression union for nylon line on one end and a compression for metal tubing on the other...that's how I connected the factory carb fuel lines to a factory efi tank. Super simple, quick and no leaks. (I cut the barbs of the end of the factory line so the unions would work)
That works too, I could have used the original nylon fuel line and that type of compression fitting. Probably would have been a lot easier, but I was afraid of the Nylon line getting to close to the Dual Exhaust pipes. The LTD came with a single exhaust so the Exhaust was on one side, the fuel lines on the other.
The 97-93 Fuel line is metal all the way to were it connects in the back, so I thought this would be safer and more durable.
1985 Ford LTD LX
I found the thread where I was wrestling with that.
http://vb.foureyedpride.com/showthre...uge-amp-Sender
Looks like if you have your original sending unit, you can swap the resistance strip for a different one that will give the correct ohms for the '87-93 gauge. But as far as what I did, apparently, i wasn't as conscientious about posting the result of the problem for posterity as I am now.
It's been a long time, so I'm not 100% sure what this mess is, but I THINK I took a Mustang sending unit, made a bracket to mount it to so the arm faces the right way, and then i ended up having to bend a new arm out of fence wire anyway because the float was then facing the wrong way.
Ugly, but it does the job...
You may not have to deal with any of that in a sedan tank though. You might be able to just slap a Mustang sending unit on and be done.
