Well did the cam swap. Ranger roller cam (8 plug head 95+) on oval port head.... Machined the followers to fit on valve stem width, now surprise the engine cranks like it had no spark plugs on.. im thinking the valves wont close completely.
Im thinking there might be differences in the hydraulic lifter, maybe theres a difference that might keep the valve slightly opened? Please any help and inputs would be awesome...
Yes its on tdc, and yes cam timming mark in place, yes i did compare the cam sprocket they are the same. Yes the dowel pin its in the same position. I did manually rotated the engine and yes all the timming marks lined up. Had to readjust the distributor since the pulley was off by one tooth. Still this would make the engine spin with no compession whatsoever, if anything it would sputter or blow up the carb...
Please any experiences?
