Okay so I bought my 81 notch about six months ago and I've been doing some work to get it in road worthy condition again. One of the things I did was relocate the battery to the trunk and ever since this it has had a really slow crank when it gets hot. The kit I bought came with 2 gauge power wire, four gauge ground wire and I ran a 2 gauge ground wire from the block to the frame rail after I took a flapper wheel to it. The ground wire off the battery goes through the trunk floor and attaches to the frame rail that had the same flapper wheel treatment. I do realize that the wire I have is on the small size but I feel the symptoms I'm getting indicate he soak. It also has a brand new starter that I put in at the same time that I relocated the battery. The car does have BBK long tube headers with factory style starter so it is a close fit and I'm sure it gets hot. I was planning on doing a voltage drop test this weekend but I'm uncertain what an acceptable reading would be.
So my question is what would the acceptable volt drop be, what is the best way to cure heat soak, do I need larger battery cables?
thank you for your time and advice.
