Sounds familiar:
While driving the vehicle home recently, I noticed the tach reading erratic. Up and down as much as 1000 RPM over what the engine was actually doing. Car runs smooth. Halfway home a few days later and the car shut off on me. Towed home and today checked it out following the shop manual for TFI-IV ignition testing. Thought the starter relay might have gone south as that happened before but the car would eventually restart but then die. Shop manual says that the stator is bad as is the culprit. If anyone has the shop manual for engine and emission testing, I began at page 15-54 and followed it to the letter. Not bad.
We know that the TFI modules are suspect and I have replaced them in times past for same scenario. I have spare Ford modules and the one on the car now is Ford. The car has not overheated so perhaps the module is still fine. I can easily check it.
The erratic tach and then the shut off seem to point to the stator, which requires removal of the distributor. I can do that and have a shop replace the stator as I have a Ford stator brand new.
Any ideas or thoughts? I'll check the TFI but according to the shop manual, it checks out fine. Fuel pressure is good as that has been a problem in times past as well. Pump does sound weak but 39 PSI when ignition is turned to run and the pump primes. Most fuel components are new as of last March, except the pump. Rockauto sent me the wrong one. Fuel filter is replaced every six months.
Thanks for the help on these mysteries.
