Up for sale are used parts from my car that I no longer have any use for.
Edelbrock Performer RPM Airgap intake manifold for 302, slight porting and gasket match, painted engine aluminum, nice shape - SOLD!
Pro 5.0 short throw shifter for Mustang T5 and T45 transmissions, nice shape. - SOLD!
Professional Products 90007 sfi approved harmonic balancer for 81+ 50oz sbf 5.0 with 4 bolt crank pulley adapter for fox serpentine setup. Was repainted due to flaking, paint isn't as great as it is in pictures. Weight could be removed for internally balanced crank, several 0 lines etched in body for various timing pointers on sbf apps - SOLD!
Ram 1525 sfi approved 50oz 157 teeth flywheel for 81+ 5.0 sbf. Bedded to a Centerforce DF disc, nice condition - $100 compared to $289 new at Summit
Comp Cams 31-334-4 solid lifter flat tappet cam, Comp solid direct lube lifters, and Comp pushrods from 5.0 sbf. Cam is .528/.528 lift, 236/236 @ .050, 110lsa. Lifters got mixed up but it shouldn't matter with these. Religiously ran with Valvoline VR1. - $100 for all
Not sure the origin of this new timing set, but the gears have E3 Ford engineering code. It appears to be a new Ford timing set. I'l include 2 piece eccentric and bolt, cam plate bolts, dowel and this piece I pulled off a fuel injected motor that was in place of the pump eccentric - SOLD!
Stock v8 power steering pulley, and v8 C.A.T. water pump under drive pulley for fox - $10 each CRANK PULLEY SOLD!
154-3601 sbf 5.0 head bolts, used a few times - SOLD!
Cale
