I will post my .02 for what its worth!
As a previous owner of a 98 Cobra, I have time in both vehicles.
I will say that the 98 Cobra did ride well and had some better creature comforts than most stock Foxes. The 4.6 DOHC loved to rev and with my Magnaflow exhaust the sound was pure Heaven to me! I loved the smoothness the Mod motor had and it was a blast to run thru the gears.
Now with that said, I was never really in love the the body style. Not a bad looking car, but just never really "Did It" for me. I guess if it had been the 99-04 style I would have liked it more, but . . . Who knows.
As for the interior, yes it was better in some ways, but again I never LOVED it! Not really sure why, but I just didn't I sat lower in the car and the door comes up higher which I didn't like. Again hard to explain, but it just didn't have the same feeling for me that a Fox does. So bottom line is I ended up selling the Cobra to focus on my Foxes.
The Capri is awesome due to the uniqueness and the rarity of them these days. Very seldom will you run into another one at the cruise in or car show. That is sad, but cool too! You won't be lost in a sea of look alikes.
The SN95 suspension is a great swap for any Fox IMHO as it gives you the 5 lugs with A LOT more wheel options to choose from. The brakes are much better and easier to work on IMHO. The SN95 rear shocks are better than the Fox shocks too. The rack and pinion has some handling and steering feel improvements too, although it requires an adapter shaft to make it work with the Fox steering column.
The SN95 interior in a Fox . . Just doesn't do it for me for all the same reasons I didn't like it in the Cobra. Yes, it can be done, although its not a bolt in affair. To me its not worth the effort and headaches. Sound deadening materials, good seals & gaskets, good interior upholstery and the Fox can be just as nice and comfortable as the SN95 if not more so. Besides again IMHO the instrument set up in the 4 Eye is the best of the Fox generations. Although I do admit the center console of the 87-93 is much better and is worth the trouble to adapter to the Four eyes.
I will caution you that the V6 T5 can be made to work with a V8, but it is not as strong as a V8 T5 and will not hold up long term especially if you are running any decent HP. Also the SN95 V8 T5 use a longer input shaft than the Fox T5 so you have to use the SN95 bellhousing or swap out the input shaft for a Fox input.
Bottom line IMHO is use the SN95 as a parts donor to the Capri and build the Bad A$$ Capri you know you want!
