Car: '86 Mustang
Engine: '94 Bronco 302
Transmission: t5
Bellhousing: Lakewood scatter shield
Problem: The car had a 10" clutch. I accidentally ordered a 10.5" clutch set. Once I realized the error I also bought the correct flywheel. The problem I now have is my starter does not bolt up. I checked part numbers for the current starter that was on the 10" flywheel vs a starter for a '94 Mustang 302. The '94 has a 10.5" clutch. Different part numbers for the 2 starters.
Question: Am I correct in thinking I need to get a starter for a '94 Mustang 302 or compatible donor?
Thanks for any answers.
