VIN
1FA = Ford vehicle manufactured in USA by Ford Motor Company
B = active belts, no airbags
P = passenger car
10 = Mustang 2-dr coupe
A = non-turbocharged 2.3L engine
8 = VIN check digit
C = 1982 model year
F = Dearborn Assembly
192858 = 92,858th 1982 Ford scheduled for production at Dearborn Assembly
Door Tag
Date - 05/82 = May 1982 scheduled build
GVWR - 3700 lb/1678 kg = gross vehicle weight rating
Front GAWR - 2098 lb/951 kg = front gross axle weight rating
Rear GAWR - 1863 lb/845 kg = rear gross axle weight rating
F0204 = 204 lbs front accessory reserve load
R0111 = 111 lbs rear accessory reserve load
Exterior Paint Colors - 8N 8D = Dark Cordovan Metallic upper (8N) and Medium Bittersweet Metallic Glow lower (8D) special tu-tone
DSO - 42 = Cleveland district sales office
Body - 66B = Mustang 2-dr coupe
VR - [blank] = no vinyl roof
Int Trim - CZ = vinyl seating w/ low-back front buckets (C), Vaquero interior color (Z)
A/C - [blank] = no air conditioner
R - [blank] = no radio
S - [blank] = no sunroof, no T-roof
Ax - Y = 3.08:1 axle ratio, non-locking differential
Tr - V = C3 automatic transmission
CC = front springs
GG = rear springs
