Results 1 to 6 of 6
    Jul 2016
    Duncannon PA
    Default Modified 2.3 cylinder head
    I have a cylinder head from a 2.3 I built years ago. It is gasket match ported with big valves and a fairly big cam. I don't have the cam card anymore so I don't remember the specs. It was on a n/a engine. It will need a new set of valve seals. It has been off the engine for a long time. It also has one heli coil on the exhaust side. This head cost me well over a $1000 dollars to build 20 plus years ago. If you can find a good 2.3 head and have all the work done today it will probably cost twice that.
    I would like to get $600 for it, plus shipping.Name:  photo 1 - Copy.JPG
Size:  118.6 KBName:  photo 1.JPG
Size:  118.0 KBName:  photo 2 - Copy (2).JPG
Size:  106.0 KBName:  photo 2 - Copy.JPG
Size:  105.0 KBName:  photo 3 - Copy (2).JPG
    I have a bunch more pics if interested. And no the valve cover DOES NOT come with it.
    Jul 2016
    Duncannon PA
    bump bump
    Jul 2016
    Duncannon PA
    I still have this for sale if interested hit me up with a reasonable offer and we'll talk.
    Is this head milled down?
    __________________________________________________ __________________________________
    1986 Mustang GT - 45,000 Miles
    Off-Road H-Pipe, Flowmaster 40's, MM Adjustable RLCA's, FRPP UCA's, BMR 1" Rear Lowering Springs,
    UPR Front Coilovers, 5 Lug Conversion, O.E. Racing Bullitt Wheels
    Jul 2016
    Duncannon PA
    Iirc only a few thousandths to make sure it was true. Certainly nothing that would raise the compression on a stock piston setup
    Thanks... I was hoping it was!
