Page 7 of 22 FirstFirst ... 5678917 ... LastLast
Results 151 to 175 of 531
  1. #151
    We went to the local Pulapart and got some misc interior screws from a new arrival fox body.
  2. #152
    was a beautiful day for a drive.. was going to hit Sonic last night but my wife was felling under the weather.
  3. #153
    St. Louis, MO.
    Quote Originally Posted by Reactor View Post
    took a great walk around video.
    https://youtu.be/8eWYLqp5wwg
    That my friend is one sweet Pony!
    Scotty
    Past Pony's.....
  4. #154
    Mar 2013
    DENVER CO, the 303
    Quote Originally Posted by HCBERICH View Post
    Attachment 111481bought my four eyes a bunk-bed
    Amazing!!!!
  5. #155
    Apr 2016
    Sprague River, OR
    Had time to finish up my headliner/ sunroof work last night. New headliner, new seals, sound deadener, and SEM Trim Black paint on the sunroof.
    Attachment 111565
    Attachment 111566
    Attachment 111567
    Join The Conversation
  6. #156
    Quote Originally Posted by fordstuff View Post
    That's a good looking car! What springs are you running?
  7. #157
    Bled the brakes today. First time so it probably took longer than it should have and a couple of the lug nuts were stuck as all hell.
    My helper didn't exactly have a lot of lower body strength either...
  8. #158
    Finished my new carport. When the wife bought me the GT back last October, I just had one of those prefab double metal carports, barely wide enough to fit my truck and boat in there. So I built a 24 x 28 carport, with concrete, steel and all, it was right at $3k. My father in law and myself did all the work. Now I got plenty of room, enough for 3 vehicles side by side, you might be able to see my boat is turned side ways behind the Mustang. So now I have a great place to do some work on the mustang.
  9. #159
    Took mine out on the school run... such a happy car!
  10. #160
    Pulled out my motor (need to change oil pan gasket and put on MM solid motor mounts) also started cleaning out 30 years worth of grease and road gunk, the steering rack was covered with 1/4 of crud!
    Tony
  11. #161
    the clothespin clips were a good idea.. i watched a youtube video from lMR and did it like they said and I held mine by hand and waited till the glue was pretty dry then moved to next section.. clips would have made it better..
  12. #162
    what backing did your headliner have?.. did you have any trouble with the dome light fitting in the precut hole of the backing?.
    Attachment 111565
    Attachment 111566
    Attachment 111567
  13. #163
    thanks...they were cheap springs off ebay.. add said 2" lower rear and 1.6 front.. may not have lowered that much... but close.. If I hadn't already had it linedup I would have cut 1/3rd of a coil off fronts... roy
    http://www.ebay.com/itm/Touring-Tech...lUGfg0&vxp=mtr
    Quote Originally Posted by HurricaneJesus View Post
  14. #164
    cool... has that SSP look..
    Quote Originally Posted by NY5speed View Post
  15. #165
    Apr 2016
    Sprague River, OR
    I converted an aero non-sunroof headliner that I had in the garage to the 4-eye sunroof headliner mentioned. It was the OEM cardboard initially and I added a layer of heavy paper to the board after cutting it to fit the 4-eye roofline, then covered it in black headliner cloth. There wasn't a 4-eye dome lamp opening in the headliner, so I measured approximately where to cut and made the hole where I needed it.
  16. #166
    Apr 2016
    Sprague River, OR
    Two items done over the weekend were a Team Z Motorsports lower radiator support (replacing my damaged one) and a set of Caster / Camber Plates.
    Attachment 111756
    Attachment 111757
  17. #167
    Got an alignment/balance yesterday. The thing is actually enjoyable on the highway now. Imagine that.
    Rag joint this weekend. Stay tuned for hilarity as I turn a 45 minute job into a two-day affair.
  18. #168
    Jan 2006
    Western MA
    Last night I ordered a roll of 3M double-sided automotive tape for the side moldings on The Rotter (baby steps....)
  19. #169
    This showed up today!
    Name:  Cobra Brake Pedal.jpg
    Now a few more modifications and hopefully the 82 GT will have some Hydro Boost brakes very soon!
  20. #170
    FEP Member Prestige Auto Body's Avatar
    Sep 2010
    Southern Indiana, outside of Louisville KY
    Reinstalled the water pump.....AGAIN........3rd time is a charm....right????
    Put the whole car together and the water pump and power steering pump are becoming my biggest nightmares........
    Name:  Water Pump 05-03.JPG
  21. #171
    FEP Power Member grtskydog's Avatar
    Sep 2003
    Carolina Beach, NC
    FiTech 600HP for the Windsor!
    Ed
    "The Dude abides."
  22. #172
    Apr 2016
    Sprague River, OR
    Picked up my widebody kit on Wednesday last week.
    Concept I drew last year to get the process started.
    Attachment 111984
    Mocking up one side to get the juices flowing and imagination. I'll put them in storage for another few months to get the car driveable before starting the 5-lug swap and widebody portion.
    Attachment 111985
  23. #173
    FEP Power Member bluesfannoz's Avatar
    Aug 2007
    Lawrence, Ks
    Dash lights were not working on the T-Machine even after upgrading all the bulbs to LED so I had to replace the Printed Circuit assembly, got a replacement from NPD. Worked like a charm. Also upgraded the voltage regulator while I had it apart. Everything but the Seat belt indicator works now. I attribute to the bulb screwdown being bad because I swapped in one of the others and it work. So posted up to the WTB because I cannot find anyone who carries those.
    Steve
    "Taillights in Your Face Jack? You've just been Dominated!"
    # Link to Facebook Dominator Mustang Fans # # Link to Facebook Predator Mustang Fans #
    # Link to Facebook Twister Mustang Fans #
    Current Stangs: Stangless
    Previously owned:
    84 Black GT, 85 Black T-Top Dominator GT # Link to Restoration Thread # 85 Dominator GT RIP 1995, 85 Predator GT, 83 Dominator GT, 82 Mustang GT
  24. #174
    Sep 2008
    Greenwood, IN
    I put both of my Four Eyes in storage up the street....for the SUMMER Yeah...I said for the summer. I have two SAAC MKI/II's coming to my place for the next few weeks so needed to make room for them. They are not mine....just storing them for a couple buddies that are showing them here at a couple local events...including the SAAC (Shelby Club) National at Indy Motor Speedway, June 8-10. Plus I need to get the Caypso LX out of the trailer and in the garage so I can start thinking about getting it running. Guess that makes me an Aero guy until later this summer....sad, I know
    Good news is its only a 5 minute walk to the storage place so I can grab the keys and go cruise one anytime I start going through withdrawal
    Jason Smith
    MCA #65481
    '82 Capri RS Resto-Mod
    '05 S-281 Mineral Grey
  25. #175
    Swapped on some 10.5" wide Cobra R wheels with 315 and 335 tires to verify fitment for another thread. Would have liked to play with the Road Racer longer, but the rain started again!
