Page 18 of 22 FirstFirst ... 81617181920 ... LastLast
Results 426 to 450 of 531
  1. #426
    Drove the pace car down the street. It did it, but was not happy about doing it.
    https://www.pintaram.com/u/sandy_jo_...814_6053912228
  2. #427
    Pulled the Zephyr's engine out of the donor car!
    Matt
  3. #428
    Sep 2016
    Anchorage Alaska
    Sold the '92 5.0 & T-5. The buyer doesn't need it right away so I can pull it this winter when I have time to swap in the 408/C6. While we were hanging out he was converted from just a patient of mine who has a passion for blue oval toys & brews good beer into a friend. No real "work" done, but still, it doesn't get much better than that!
  4. #429
    Didn't work on my car today but did pick up this x pipe off of CL for $50.
  5. #430
    Continued painting the belly. Started a while ago, when the engine was out, and had done all the engine bay and around the the inners to the fenders and all underneath as far as the diff, when I decided that was far enough for then, without having to pull the rear end apart to continue any further. I had gone that far while the engine was being rebuilt, and once the engine returned, I was eager to get the car registered for the road for the first time since I had owned the car. [86 GT Convert]. As I had now to replace the control arms, thus giving the access to continue the process.
    Name:  under paint 1.jpg
    Name:  under paint 2.jpg
  6. #431
    Feb 2006
    Allentown, PA
    Officially back on the road after (too) many years sitting waiting for attention.
  7. #432
    FEP Power Member racerxmd's Avatar
    Sep 2007
    Rockville,MD.
    Purchased a new Dart SHP block for my new'85GT T-TOP car.
  8. #433
    Sep 2007
    Rockville,MD.
    SHP https://imgur.com/gallery/4k5oO
  9. #434
    Apr 2016
    Sprague River, OR
    This last week I've been able to accomplish a lot. I got the front widebody fender at least started to be mounted. I still need to fix the door fit, but it will be good enough to move on the other side and get it ready to fit the hood and the front bumper assembled. The rear fender is cut out and ready for the fuel door to be fitted and then the widebody fender can go on permanently. I also had enough time to get the rear of my nothcback put back together with everythign cleaned and sealed (and the redone taillights).
    Attachment 116426
    Attachment 116427
    Attachment 116428
    Attachment 116429
    Join The Conversation
  10. #435
    double post
    86 coupe
    1993 GT
    My 10 Sec street cars
  11. #436
    A quick detail after getting her back running
    86 coupe
    1993 GT
  12. #437
    Default Fall/Winter prep check drive
    Cold rain day.
    Undriven for 3 weeks due to flush tee-heater hose clamp leak.
    Replaced tee. Had a flat spot.
    Read over-tightened worm gear hose clamps can warp plastic fittings.
    Repair ok.
    Looking for right size spring clamps
    Aired up tires. Low due to colder fall weather setting in.
    During this, a brief weird hail size sleet weather event happened.
    Added 1/2 tank gas, hopefully cool weather blend not leftover summer blend.
    Stupid little wet Honey Locust tree leaves fall all over the place. Neighborhood trees.
    They get down under the car's trim moldings, rear spoiler, and are hard to get out.
    Decompose to mush, attract dirt, then try to start rust.
    Stick to glass.
    Had to add a screen under the cowl grill to keep them out of there.
    Next to fall is their ugly brown banana peel like seed pods.
  13. #438
    Adjusted the Holley two barrel's idle mixture screws a wee smidge outward (richer) for better, smoother idle with the somewhat colder temperature outside.
  14. #439
    Mar 2015
    Rose Hill,Kansas
    Just received my new headers. BBK un equal length ceramic. Went with these for ease of installation, and later repairs if needed. Will lose a few ponies but new engine will still be more than I need.
  15. #440
    FEP Member Tcapper's Avatar
    May 2017
    Stonewall, Manitoba, Canada
    Put her away for the winter.Name:  Mustang 041.jpg
Size:  83.0 KBName:  Mustang 043.jpg
Size:  79.4 KBName:  Mustang 045.jpg
  16. #441
    Sep 2007
    Rockville,MD.
    Received the new fuel tank sending unit today. Cleaned the Aeromotive fuel tank and installed the sending unit. Want to adhere new the padding on the tank. Need to order that. But in the mean time, want to clean up under the area where the tank is to be installed. Maybe repaint the underside.
  17. #442
    Pick up an intake manifold gasket set for an air gap install and a new carb.
    Sent from my SM-G892A using Tapatalk
  18. #443
    Apr 2016
    Sprague River, OR
    This weekend I finished up the rear passenger side flare and fuel door, then swapped my 8.8 axle to 5-lug and disc brakes.
    Attachment 116685
  19. #444
    Quote Originally Posted by Tcapper View Post
    Me too
    -Randy
    '83 Mustang GL notchback - 351w - T5Z
    '84 Mustang GT350 20th Anniversary Hatch #2808 - 302 - T5
    ''92 Mustang LX Hatch - 2.3t - IRS (in progress)
  20. #445
    Attachment 116685
    Are you going to blend them in or leave them like that?
  21. #446
    Apr 2016
    Sprague River, OR
    Quote Originally Posted by brian.aughe View Post
    The flares will be left as they are, like a modular added piece. I want them to be removable if needed instead of bonded.
  22. #447
    Mar 2015
    Rose Hill,Kansas
    Dropped off distributor today at engine builder so he can install. Just need to fab spark plug wire holders. I was amazed how clean and sharp looking my engine is. Don't have all specs handy right now. Do know compression is 9.8 and holds 8 quarts of oil with filter.
  23. #448
    Jan 2006
    Western MA
    ^^^ looks like a piece of jewelry
    Me - I haven't done jack to any of my cars for the last month or so.
    I need to get the SVO in the garage and pull the trans so I can get the flywheel resurfaced and change the clutch.
  24. #449
    Mar 2015
    Rose Hill,Kansas
    Thanks, even though it took awhile the engine builder is super meticulous. Hopefully start removing old engine over Thanksgiving break.
  25. #450
    Quote Originally Posted by rodster View Post
    Is that the High School in the background?
