This is fully loaded 4 speed car with T-Tops, 140 speedo, AC (needs charging), CC, rear wiper, PL, PW, power hatch release, and USED Recaro seats.
It is currently all original with the exception of the 8.8 rear end with 3:73 gears, KONI Quadra shocks, and dual exhaust setup with Magnaflow H-pipe and cat back, aftermarket radio and Recaro seats. I also have all the original paperwork from the initial sale.
There are small rust spots (size of a quarter on the rear quarters). Underside is solid...some light surface rust. Doors/Hatch are decent (not perfect)... Front seats are used and the door panels need replacing.
Car is now on 86 SALEEN RIKEN mesh wheels and Firestone wide ovals. Also put in a new battery, replaced spark plug wires with new Ford Racing, plugs, MSD cap and rotor. Also replaced power lock actuators.
I hate to let this go but, I have an opportunity to pick up a 1983 loaded CC and I have no room for three so, the 82 has to go.
Theses parts go with the car
The complete rear window setup (including drip rail).
USED door panels
USED Gauge bezel
NIB fuel tank
NIB fuel sending unit
NIB SVE upper and lower control arms
NIB MM Sub frame connectors
NIB Fuel Tank, straps and hardware
NIB Fuel Supply and Return Lines from classic tubing
NIB Speedo cable
NIB High and Low beam head lights
Looking for $4000, please text @ 8174016467[/B] [/B]for any questions.[/ATTACH]
Having trouble loading pics, will add more later.
