Hey im new around here, currently in Guatemala city, new in the foxbody and mainly in the 4cyl draw thru pain.... Hahaha im pretty used to mega squirt, gm, and hp tunners side. Not the old stuff, but sold an fbody formula lt1 and got this awesome barn find in part of the payment.
Its a 1979 mustang 2.3t 4speed trans and the best is that its been well kept. Paintjob may be needed but never been crashed, has the original custom faided paint job.
The engine has been rebuilt 1000 miles on it. This friend wanted to rebuild it completely.
Since this is the only site that actually talks about the 4eyed carb turbo might aswell just join share and well get some help with the experienced buddies around here.
This is what i have installed, turbo timer, aem wideband, autometer boost gage, 2.5" custom down pipe dump in the rear end, choke butterflies deleted, smothed carb top, bmr rear control arms, and volvo electric fan. Initial timming in 10btc vac of while set, 7psi on mec fuel pump.
Heres where im stuck:
1) how does the duraspark retard timming "if it even does" on running operation? I know it retards to start the car... Or locking it would be the best option for a car that is ment to be driven daily? I feel it needs to rev a lot more, cant seem to feel boost, but a steady slow pull. And the car is harsh past 4500 rpms. When i think this is where it should start pulling hard.
2) How much boost will it handle, planing on only using 95oct, in the future either water injection or water/meth (if needed). Using a boost controller inside to boost higher if willing
Figured from different threads here the vacum madness, decided to delete everything and staying on basics: brake boster where the vac tree was, wastegate on the front manifold vac, and the distributor on the holley 5200 carbs side lower vac. No egr no nothing else but a/c and heater,
I had a bad issue that the carb leaned out in 3rd gear, was the float adjustment, pretty simple carb to mess with. Now having a steady safe 11:1 afr wot alk the way to high revs.
I dont want to take on the option just yet to make a blow through setup, or swap to the efi engine... If anything i would fabricate my own intake and exhaust with a bigger turbo and using a megasquirt... Just dont know if its worth it just yet.... And if this engine dies probably ill swap a 5.3 chevy instead .
Sorry bout the whole explanation but im quite exited on this light weight combo and want to build a little sleeper to have fun with...
