Results 1 to 10 of 10
    Default 3.3 Vacuum nightmare..
    So Im getting ready to pull my hear our out or just take it to a shop. But Seems I cant get the vacuum system right. It seems like the distubitor and the egr vavle almost always have vacuum. I tested the vacuum switch and it good...Here is the map im working off of. The other wierd thing im fighting is the coke never seems to want top open all the way when it warms up...
Size:  69.8 KB[reflist][/reflist]
    Now that the sun is out here is what I have going on.
    This'll help ya...
    I want you to know I've never, ever had a problem with any of the 1981 3.3 Mustangs vac fittings, carb operation, ignition, and that's because I always detail what parts go to what by taking videos and camera shots. When some Alan Beresford B'Stard has being playing with it, then its like restoring democracy to a banana republic...it'll fight you every step of the way.
    My VECI is
    E1 BE 9C485 CA, DCK
    Mine has Air Conditioning, so it has the throttle kicker adjustment line.
    Yours might not have that.
    But its got your Secondary Air, since both our cars are California Emissions.
    My cars calibration (as per the Rocker Cover) is IJ 204 AA, yours is xx 205 BA, so it might be a little different.
    And the mid winter sun screws up a good picture...
    Red goes to spark line on the carb.
    AIR pump vac line has a VRESER on it
    Front of the engine follows the VECI schematic, with "FRONT OF ENGINE" in DCK and 1-12B-R0 1981
    Left most Blue VCV connected to VCKV and DV
    Second Green VCV right most, and fed off ACV (out of view, its biege/brown/tan, and clips to the rocker cover).
    Black VRESER hose off to far right, then
    Colors are the key. These are the left to right colors, with the various valves and lines and links to match up.
    This is the VOTM system (electric SOL V sits on rocker cover),
    and the vac lines to the Evap canister
    The air pump details depend on if your car has secondary AIR.
    1. Ford never, ever did any favours with specific information on this carb. Its all nested among Fords generic year by year Vehicle Emissions Control Information
    VECI, which governs
    Vacum, Emissions, Carb, and Ignition line settings
    The problem is Ford never had VECI diagrams for 1978 to 1980 1-bbl carbs, as there were
    X shells with Carters,
    Foxes with Holleys, and they made lots of 1946 model changes between CA and non CA spec with respect to the air pump, secondary AIR, and then the new B code 200 and C code 250 changes in 1980.
    On my 1981, ignition to carb fitting has a priority delivery. It was a yellow line that was played off the ported vac against a dioded vac line on my VECI.
    If you follow the VECI with all the letter codes broken out in active words, its easy to find, but it has just confused everyone else. ...so we used the pictures RED 78' supplied on his copywrited website to elaborate the diagrams. But be warned, his info is 1978 to 1980 specfic, and that doesn't help us 1981 guys who have the Secondary Air 3.3's
    The reason why the 1946 is hard to tune is the missinformation and changes made to it from 1980 to 1981...they weren't ever feedback carbs, but they did have solenoids similar to the Feedback Carter YFA's used on Jeeps, F-trucks, E-vans and 2.3 Foxes and Rangers. It took me about four years to wade through the missinformation that happens because the carb looks like a feedback YFA, and requires a vaccum pump to set the pulldown choke, and has an A/C throttle kicker VOTM sesnor just like the Feeback Jeeps have.
    Its just a 1-bbl Holley carb, but because its not a 1901, 1904, 1098, 1909, 1920, 1931, 1940 or 1945, the 1946 (and the similar 2.3 Tempo/Topaz 1949/6145/49/51/53) confuses the heck out of every Ford guy. even the smartest people.
    2. Real quick, the choke is a pulldown choke unloader, and absolutely needs autocratic Czar set up as per the Ford manual set up requirement with a hand operted vac pump. As long as you've used the right process, it will work fine, and open all the way.The choke set up for 1-bbl carbs changed in the early late 70's, early 80's to the 25 psi of vac applied to the choke unloader.
    you have to follow the time honoured apply vac procedure as per VECI , also common with the early 3.3 1-bbl
    Expunge any thinking that the 3.3 carb is a feedback carb. A/C cars do have a control line to the throttle kicker, but its NOT a feedback carb. The "apply vac procedure" was also a primary way of triggering the code reader process in the 1980-1983 EECIII 5.0 CFI, but no 3.3 ever has been a feedback carb. Any references to Motorcraft 2150, VV 2700, VV 7200, Carter YFA, CFI, EEC II, III, IV, or MCU aren't relevent in any way to our 3.3's. These T, B and X code 3.3's never had a electronic feedback computer with the 5 or six wire computer reeder link.
    Ford were just saving money in there Vehicle Emissions litrature, but for I6 3.3 guys, that just makes life to blqqdy dificult. Don't spend time looking in a black room for a black cat that isn't even there.
    3. RED 78' is the best guy on the net for our I6 Fords, doanchaknow? But his info is 1978 to 1980 specfic.
    See https://fordsix.com/viewtopic.php?f=...582790#p582790
    I think RED 78' might have the two S and E ports around the wrong way in his picture, and Moostsie in his description too. S is certainly the down low port on the passenger side. Unlike the YFA, the Holley 1940/1945/1946 and 614x/615x family has the float bowel and choke at the back, and it has confused a lot of people. The fuel inlet isn't where the float bowl is, and some Autolites have the choke at the front instead, so its all a bit of a mish mash. Just as well you guys haven't got a RHD Fox 3.3, or the passenger side will be different depending on which country your in.
    :bang:
    Clockwise from front passenger side of carb is S, E, then V and then BV.
    Items in the diagram in alphabtical order have numerical numbers from the 74 to sometimes 82 item list below. I'm gonna say it twice. Items from 75 to 82 are just numbers to put duplicate the VECI items in order, but you'll get the idea for oddball terms
    The full list of items and codes on the VECI is
    are
    A Occurs Two times on the VECI, Item 82
    A/CL BI MET, Item 3
    A/CL CWM Occurs Two times on the VECI, Item 4
    A/CL DV, Item 2
    ACV, Item 5
    AIR BPV, Item 7
    CARB BV, Item 75
    DIST, Item 11
    E, Item 37
    EGR, Item 12
    FUEL T, Item 76
    LCV, Item 60
    MAN VAC, item 17
    PCV, Item 81
    PURGE CV, Item 30
    S, Item, Item 35
    SA-FV, Item 80
    SLEEVE, Item 77
    SOL V, Item 19
    TO ATMOS, Item 78
    TVV, Item 28
    V, Item 21
    VAC-SWITCH ASSY,Item 79
    VCKV, Item 22
    VCV 2X, Item 44
    VDV, Item 63
    VOTM, Item 53/73
    VRDV, Item 26
    VRESER, Item 23
    VREST, Item 24
    myle860, the VECI we both have and the Holley 1945 Mopar video info says the Spark valve is the one down low, the E is the one above it.
    1981 VECI's were the first Ford cars with full VECI schemtics.
    Again, working it out is 1980 to 1983 B and X code specific. It can put a fair old strain on the grey matter finding out where any of this stuff goes without an existing car to copy. The lines have color check valves/diodes to get priority flow that changes the vacuum source form Spark to Ported or Manifold via the later model vaccum and emission lines. This is very much like what the Mustang 4-bbl M codes from 1983 to 1985.
    The Ford 1981 California emissions VECI list is for Fords trained service people, and not people like us,
    I have had to use an 82 item name and claim it version of the list again and again; it has seven other visual VECI code items from 75 to 82, but its based on a hard return, digitized version of http://myzephyrs.com/vac_part_name.htm
    Your important items are:
    Item 8 BV: Bowl Vent (on top of the float tanks)
    Item 17 MAN VAC: Indicating Manifold vacuum-Vacuum source for brake booster
    Item 21 V VAC: short for Vacuum
    Item 35 S Spark Port
    Item 37 E EGR Port
    Item on the VECI diagram are listed in red.
    The full 74 item list excluding 75 to 82.:-
    1 A/CL: according to Ford, that IS the air cleaner
    2 A/CL DV: Air Cleaner Duct & Valve
    3 A/CL BI MET: Air Cleaner Bi-Metallic Valve
    4 A/CL CWM: Air Cleaner Cold Weather Modulator
    5 ACV: Air Control Valve
    6 AIR: This is a Secondary air injection Ford calls the Thermactor, short for Thermal Reactor. CA vehicles are installed with it as standard. Air Injection Reaction is what it stands for.
    The thermactor system consists mainly of the air pump, the air pump diverter and bypass valves, TAB and TAD solenoids (if equipped) and the catalytic converter.
    7 AIR BPV: Air Bypass Valve (aka Thermactor Air Bypass TAB)
    9 CARB: Carburetor
    10 CPRV: Canister Purge Valve ( PURGE CV
    11 DISTistributor of course.
    12 EGR: Exhaust Gas Recirculator
    13 EFCA: Electronic Fuel Control Assymbly
    14 FLTR: Filter
    15 FPR: Fuel Pressure Regulator
    16 IVV: Thermactor Idle Vacuum Valve
    18 MAP: Manifold Absolute Pressure
    19 SOL V: Solenoid Valve
    20 SV-CBV: Carburetor Fuel Bowl Solenoid Vent Valve
    21 VAC: short for Vacuum
    22 VCKV: Vacuum Check Valve
    23 VRESER: Vacuum Reservoir (Actually VRESER just stands for Vacuum Reservoir. It may or may not have a valve or Solenoid Valve inside it.
    24 VREST is a vacuum restriction, usually at the thermally controlled valve on top of the thermostat housing.
    *On 87 4V 460 F250 truck it is a simple blue plastic orifice inline with the vacuum line.
    25 VRV: Vacuum Regulator Valve
    26 VRDV: Vacuum Retard Delay Valve, as these can be used on more than just the distributor.
    27 TVS: Thermal Vacuum Switch, and is different to a Dashpot. On Fords these are usualy located in the air cleaner.
    28 TVV: Thermal Vent Valve. On fords they are mostly controlled by ambient air temps. Simular to a TVS. Located between the carb and the charcoal cannister.
    29 PVS: Ported Vacuum Switch: Very simular to TVVs except on Fords they are used in the cooling system and are controlled by water temps.
    30 PURGE CV: Vapor Canister Purge Valve
    31 EVAP CANISTER ASY
    32 Ford refers to theirs as an Idle Speed Control (ISC) solenoid
    33 Idle Boost Solenoid (Orange Knob on 81, 82, 83 A/C Equiped 3.3's) or Throttle Kicker Control
    34 Carburettor throttle Solenoid Positioner (Anti Dieseling Valve/Idle Stop Solenoid)
    35 Spark Port
    36 EGR Actuator
    37 EGR Port
    38 CAT is catalytic converter;
    39 ENG is engine;
    40 ACT - not sure, but on EFIs it means Air Charge Temperature sensor
    41 Inlet Air Temperature Control
    42 Green DVCV 2 port PVS vaccum switches
    43 Blue TCVV 3 port vaccum switches
    44 Dual Diaphram Distibutor
    45 Black SDV Cold Start Spark Delay valve
    46 Black SDV EGR Vaccuum delay valve
    47 Deceleration Valve (PVS Cold Start lockout Dampened, Non Dashpot)
    48 Non dampened or 2 port PVS (dampened) control EGR
    49 Attitude and Position Fuel Trap
    50 PVS Vacuum with Sintered Line Filters
    51 Close Limit primary or Main Jets,
    52 Lead plug sealed idle screws
    53 Carburettor throttle Solenoid Positioner
    54 Evaporative Emmission Control System
    55 Anti Backfire Valve
    56 EGR Valve Actuator
    57 Vacuum Regulator/Solenoid
    58 Solenoid Valve
    59 Venturi Vacuum Amplifier
    60 Load Control Valve
    61 EGR B/P Transducer
    62 Signal Conditioner
    63 Ported Pressure Switch
    64 Vent Valve Vacuum
    65 Vacuum Controlled Switch
    66 Vacuum Controlled Switch (Cold Temp)
    67 Vacuum Controlled Switch (Decel Idle)
    68 Vacuum Delay Valve
    69 Vacuum Vent Valve
    70 Delay Valve Two Way
    71 Ignition Timing Vacuum Switch
    72 Ignition Pressure Switch
    73 TK (Throttle Kicker)
    74 Mushroom caps for charcoal fuel vapor canister vents.
    VOTM, Item 53/73
    CARB BV, Item 75
    FUEL T, Item 76
    SLEEVE, Item 77
    TO ATMOS, Item 78
    VAC-SWITCH ASSY, Item 79
    SA-FV, Item 80
    PCV, Item 81
    For the later 1981 onwards 1946C carb, this is the full schemtic. You have to push the Magnifying glass icon to get it in full size.
    http://i1215.photobucket.com/albums/...carburetor.jpg
    Green line to EGR
    Questions like "which of the many vacuum connections are you running distributor vaccum? Running PCV vacuum off the adapter, and I'm puzzled by the many options."
    Its easy when you have vac line and emissions line pictures!
    Then the red, yellow, green and blue color coded make simple sense
    http://i1215.photobucket.com/albums/...e6/th_025r.jpg
    The quick answer is the yellow line from the Duraspark goes to the double line to the base of the passenger side of the carb. See 6635, 6636, 6637 and 6741-1 below
    http://i1215.photobucket.com/albums/...6/IMG_6635.jpg
    http://i1215.photobucket.com/albums/...6/IMG_6636.jpg
    http://i1215.photobucket.com/albums/...h_IMG_6637.jpg
    http://i1215.photobucket.com/albums/...IMG_6741-1.jpg
    Red Spark sustain port on pictures 8861
    http://i1215.photobucket.com/albums/...6/IMG_8861.jpg,
    8862 for the red coded stuff http://i1215.photobucket.com/albums/...6/IMG_8862.jpg.
    Yellow is 8863 http://i1215.photobucket.com/albums/...6/IMG_8863.jpg
    8864 is idle stop http://i1215.photobucket.com/albums/...6/IMG_8864.jpg
    8865 is power supply wires http://i1215.photobucket.com/albums/...6/IMG_8865.jpg
    8853 http://i1215.photobucket.com/albums/...MG_8853b-1.jpg (air cleaner detail),
    8854 http://i1215.photobucket.com/albums/...6/IMG_8854.jpg,
    8858 http://i1215.photobucket.com/albums/...6/IMG_8858.jpg,
    8859 http://i1215.photobucket.com/albums/...6/IMG_8859.jpg,
    I have about 130 pictures and videos itemised in this list. One of them will be just the info you need, so hange in there.
    1 3416
    2 3417
    3 3418
    4 3419
    5 3420
    6 3421
    7 3422
    8 3423
    9 3424;
    10 3425
    11 3426
    12 3427
    13 3428
    14 3429
    15 3430
    16 3431
    17 3432
    18 3433
    19 3434
    20 3435
    21 3436
    22 3437;
    23 3438
    24 3439
    25 3440
    26 3441
    27 3442
    28 3443
    29 3444
    30 3445
    31 3446
    32 3447
    33 3448
    34 3449
    35 3450;
    36 6376
    37 6377
    38 6378
    39 6379
    40 6380
    41 6381
    42 6382
    43 6383
    44 6384;
    45 6385
    46 6423
    47 6424
    48 6425
    49 6426
    50 6437
    51 6444
    52 6445
    53 6446
    54 6447
    55 6448
    56 6449
    57 6450
    58 6451
    59 6452
    60 6453
    61 6454
    62 6455
    63 6456
    64 6470
    65 6477
    66 6483
    67 6488
    68 6560
    69 6570
    70 6511
    71 6541
    72 6542
    73 6543
    74 6567
    75 6594
    76 6572
    77 6573
    78 6574
    79 6575
    80 6576
    81 6577
    82 6578
    83 6579
    84 6580
    85 6581
    86 6582
    87 6585
    88 6584
    89 6585
    90 6586
    91 6587
    92 6588
    93 6589
    94 6594
    95 6590
    96 6591
    97 6592
    98 6593
    99 6594
    100 6595
    101 6596
    102 6597
    103 6598
    104 6599
    105 6600
    106 6601
    107 6602
    108 6603
    109 6607
    110 6608
    111 6610
    112 6611
    113 6612
    114 6615
    115 6616
    116 6613
    117 6614
    118 6374
    119 6375
    120 6741-1
    121 8860
    122 8861
    123 8862
    124 8863 is Yellow line
    125 8864 is idle stop
    126 8865 is power supply wires
    127 8853 (air cleaner detail),
    128 8854
    129 8858
    130 8859
    I think what is happening is the egr valve is open too early and its advancing the timing at the same time. When I disconnect and plug those 2 lines the car runs fine. Also had to rebuild the carburetor seems there was a extra screw in the accelerator pump binding that up
    See below
    Four questions.
    1. What VECI sticker numbers. Could you post it cleaned up a little with a rag, and post the E1 XX XXXX XX DXX num?
    Mine is E1 BE 9C485 CA, DCK
    It has LHS and RHS info.
    Here's my RHS info broken down. Yours is different. I need to see both sides if you could manage it, cuase I reckon the EGR line routing is different on non A/C cars.
    2. Whats you full engine calibration sticker code?
    Mine is IJ 204, with 1-12B -RO on the rhs.
    Yours is differnt, and the RHS no is the calibration VECI on RED'78's website
    IJ 204 AA, but 1-12 RO is the clibration VECI you check those lines agianst, which you'll find on RED'78's web site.
    My cars calibration (as per the Rocker Cover) is IJ 204 AA, yours is xx 205 BA, so it will be DIFFERENT.
    Already, without all the VECI visible, your Point "A" is a checking point in the instructions on the LHS of the VECI sticker lookes different.
    So there is a difference between yours and mine,
    Because you don't have A/C, your set up is missing an extra vac check point "A" on the EGR circuit. And you don't have the idle control SOL that A/C cars do, so Ford will have a slightly different vac arrangement for secondary AIR.
    I'm pretty sure the problem is simple, and a variance on the set up I had on my 81 A/C auto.
    If you post your VECI diagram in full like mine, we can see where the EGR line goes EXACTLY.
    Ford are pretty smart, there will be a difference if there is only one Hand Pump vacuum check point.
    I note that BTD has a CA emissions 81, but its 4-speed T4 manual but has no A/C either, so no idle kicker, or what is called variously the VOTM system (electric SOL V that sits on rocker cover of A/C cars)
    3. Note BTD's AIR pump is long since gone, but is Is there a diffrence in the line arrangement?
    Here is it here.
    Engine 3.3 200
    I'll ask for VECI's from each of you because its likely to be something really simple like that.
    4. As for the carb, what part do you think has the extra screw that's binding it up?
    http://s1215.photobucket.com/user/xe...retor.jpg.html
    Everything has a number if your eyes are good enough.
    Kits are generic, and Mikes cars and others haven't yet done a rebuild video on the 1981 to 1983 1946C Holleys, there are a few bowle vent and other differences.
    Another one is the check weights. Its easy to sub in the wrong part, and sometimes, they may have been wrong from previous service.
    The sticker is just one I found at a junk yard to try figure out what im dealing with. My original hood is long gone. The car was half capri we I got it. The valve cover is one from a junk yard so I dont think its the correct sticker anyways. For the carb I broke down and bought a NOS one and bolted it on. The screw was stuck in the accelerator pump spring when I found it.
    Cool. Thats normal :-)
    Nothing stays original normally. I was just lucky with my 81 3.3, and nothing was changed.
    You'll get this beat. NAVYCAT whent through the same head bending sh!+ for his CA emissions 81 White Magic Capri...a long process of repeatedly trying components to find that all the while, the stock parts were okay. The car is now in Australia with the smog gear off,and there are photos of it below.
    Afew notes
    Line Color codes are:-
    Quote Originally Posted by 1986Saleen View Post
    They often correspond to a stripe color or hose color, but not always.
    Typical Color Codes - Vacuum Diagram
    Red = Main vacuum
    Green = EGR function
    Orange = Heat control Valve (exhaust & intake) (AKA heat riser but more complex)
    Yellow = Distributor advance / from the TAD Solenoid (driver's side Forward Solenoid) to the TAD (Diverter) Valve located at the rear of the Intake Manifold (nb//On V8's, I6's, its normaaly drivers side - xctasy)
    White = EGR vacuum (source)
    Black = Mainly used for the Evaporative emissions control
    Black = Thermactor ACV or Diverter valve
    Blue = Throttle Kicker control
    Pink = Thermactor Air Bypass Valve (BPV) (from the TAB Solenoid (driver's side rear solenoid) to the bottom of the Thermactor Air Bypass Valve)
    Quote Originally Posted by RickFury View Post
    Can someone tell me what the difference is between a Vacuum Check Valve (VCV) and a Vacuum Delay Valve (VDV)?
    Quote Originally Posted by 4SPDFOX...+1 View Post
    Just to make your statement on the VCV a little clearer for the asker, a vacuum check valve will hold against vacuum indefinitely in one direction- meaning vacuum can travel through the valve unrestricted in one direction but it can never travel through the valve the opposite way. It's just like a standard electrical diode, if that helps at all.
    Could you confirm that you have item 19/53/73 hooked up via the dashed line in this revised VECI?
    If so, Tthen you have one minor matter...
    Your VRDV to the air cleaner is Bluee Black White, not Red Black White like mine.
    Everything lookes right, BUT there's a major issue for you....
    1. My EGR valve was a 135. A replacement might not be the right one for what is an A/C equiped VECI in your case.
    2. Yep, that's right, its all that A/C stuff the might be messing things up.
    3. The Ford Service Manual VECI 1-12-RO has been amended to include:-
    Sol V, Item 19, an idle Vac solenoid.
    SOL V is only when A/C equiped, and controls the VOTM. Its those dotted lines, and its a lot of extra stuff that has a tuning specfic that you'll have to follow from post #3 above, LHS of the E1 BE 9C485 CA, DCK VECI.
    All of it.
    Differences are:
    1. Item 73 is actually the VOTM (Vac Operated Throttle Motor), not an electric motor, but operated by item 53/73, the Carburettor throttle Solenoid Positioner or TK (Throttle Kicker) in other FoMoCo speak. It was put into place elseware to fix idle problems with A/C, but also in Aussie 1976 to 1982 Falcon sixes.Without it, idle is not well modulated.
    2. You don't have A/C, yet have all the A/C VECI gear. That means you have to treat it as non running A/.C.
    I.e. you have the A/C throttle kicker, so you need to assume A/C off and tune as per the LHS of the VECI.
    Similarly Your Green Purge CV will have to use the full A/C circuitry , and your carb will have to use the VOTM and all the dotted lines.
    It'll be venting if the dotted line A/C VECI stuff isn't hooked up. . The wire hookups from the non existant A/C unit will have to be switched like they are on A/C cars. Or it'll e open looping to wrong feedback data. Its not a feedback carb, but if the A/C models VOTM is on the carb, it'll need to work if its looking for a pulse Width Modulation value or analogue signal. Mis tracking idle was a typical early 80's issue.
    If I were smart enough, we'd figure what was different between the A/C and non A/C carbs and Purge CV and all the dooted line crud, and set it back to non A/C simplicty, but I've never seen a non A/C 1-bbl Holley 1946C, and mine worked perfct even with broken A/C, so i'd advise you just continue.
    If you can a find a White black and red VRDV to Item 4, the A/CL CWM, it might help if you still have matters after tuning the A/C as per the VECI.
    They have diiferent specs, and although these are not up to date, you can see how much the spacs vary for 71-78 Mavericks and Cometes.
    Quote Originally Posted by mrriggs View Post
    I realize this is an old thread but it keeps coming up in my searches to make heads or tails of the vacuum system.
    I found this list of FORD vacuum delay valves which may be more relevant to our cars than the list previously linked to.
    Spark Delay Valve
    Time in Seconds
    Color Code I.D. Number Minimum Maximum
    White/Brown 2 2 5
    White/Green 20 9 20
    Black/Grey 1 1 4
    Black/Brown 2 2 5
    Black/White 5 4 12
    Black/Yellow 10 5.8 14
    Black/Blue 15 7 16
    Black/Green 20 9 20
    Black/Orange 30 13 24
    Black/Red 40 15 28
    The list was found here, http://www.1bad6t.com/Maverick/repai...ntrols_02.html
    In one post, our 2.3 Turbo carb Ford guy gr79 helped another member pacecartodd get three new diodes from the NPD catalog (pages 105 to 145 2015 ). #37 on Page 2.
    http://vb.foureyedpride.com/showthre...8carb%29/page2
    So there is all the support in the world for you.
    I think you'll find that Ford were pretty strict getting those emissions down, and that is all you need to do is follow the stock, original VECI lines for an A/C Capri.like NAVYCAT / FoxyCapri's.
    Oh, and here is what it all lookes like unhooked...
    Quote Originally Posted by Foxy Capri View Post
    G'day Dean, you'll have to excuse my ignorance, but I have no bloody idea what all that emissions stuff is or what it does. I'm an old school mechanic, plugs, points and an oil change, that's for me!
    Anyway, attached are 2 pics of a lot of the rejected stuff off my I6 200, along with a close up of the item I thought that you were talking about. Hope all this helps, and I definitely don't have the EXH light. Cheers, Terry
    Attachment 81049 Attachment 81050
    If not in service, the idle tacking falls out due to component aging or sometimes just the akwardness of finding info form Ford, like this part below. Its in perfect shape, but everything is cutom to application, and it has a resister in line for some applications. So just a contiuity and restance test can rsult in the wrong thinking. If one piece of info is missing, you start to think its a component fault, but that is seldom the case....
    Quote Originally Posted by jessesandy View Post
    Thanks. Although my components are operating in reverse to achieve the same operation.
    My '83 is an early build (Oct. '82). (if that might explain the differences ?)
    Anyway, my vacuum switch is definitely closed (13.2 ohms) at atmosphere (from 0 to 8 inches)
    and the goes to open circuit with 8 inches or more.
    Attachment 108554
    Also, my TAB and TAD solenoids "pass through" vacuum when they are not energized.
    When energized the solenoids block the source vacuum and vent the "device" to atmosphere.
    The end result is operation just as you described.
    What is the reason to send thermactor air upstream during heavy load ?
    Todd H.
    Quote Originally Posted by JacksAO View Post
    Your switch is bad. You should have 0.0 to 0.2 ohms across closed
    contacts. 13.2 ohms is indicating that the contacts are ether dirty or pitted and are not making good contact which will cause a voltage drop through the switch.
