Just kicking around an idea. I have a 93 mustang with a 408 stroker and a tremec 3650. The car runs off the factory computer with a sct chip. The body needs work so I was thinking about swapping this combo in a very clean fairmont. Being that the 93 runs and drives I have basically everything for the swap. A few things I'm concerned about are
Hood clearance. I had a tough time finding a hood that would clear the trick flow intake. I used a factory crossmember and stock height motor mounts. That could be my issue
Also how could I run this factory ecm and harness in this car? Would I have to swap over a dash harness and everything else? Or an aftermarket ecm or convert to carb?
The fairmont is an auto. Would I have to cut the floor to get the 5spd to work. And what about the clutch cable?
Has anyone doen this swap? Thanks
