At the very least, that switch controls the canister purge solenoids and the dump solenoid for the thermactor dump valve.
(I didn't verify if it is also used to shut off A/C at WOT)(But you don't have A/C anyway ?) (And I'm not saying this is all it controls)
The WOT switch is a normally closed switch. When the throttle is wide open and "presses" the switch, the electrical contacts are open.
When the ignition is on, the canister purge solenoids (normally open to air/vapor flow) activate and block the hoses from carb bowls to charcoal canisters. At WOT, the switch deactivates the canister purge solenoids.
At WOT, the switch activates the dump solenoid which cuts vacuum to the thermactor dump valve which causes smog pump air to vent to the atmosphere.
As far as killing the battery... ?!?
Is it charging ?
What happens, the car stops running ? As all ready mentioned, is battery voltage too low for ignition system to work ?
Also, the WOT switch is fuse protected (if, for example the insulation flakes off the wires and short to the motor) (ask me how I know
