Results 1 to 17 of 17
Thread: Build Sheet?
    Default Build Sheet?
    Came with my car, anyone know what it means?
    Can you post a pic of the buck tag from this GT? I believe it has the "hood graphic delete" option but I would like to see the code from the buck tag
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    I sent you a PM. That sounds correct person I got it from put the hood graphic on.
    I'm curious, is there a list of Ford codes somewhere ?
    There are lists of GM RPOs and decoders everywhere, but the Ford codes are a bit cryptic and can't find anything similar.
    Not a list as far as I know. I've been decoding for about 20 years. I started doing it over at the GT registry but have been doing it here for quite a while now. I actually figure out a few more build sheet codes as I was putting together a decoder for them.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Is this it?
    Yes, that's it. Aaaaaand it has the code I was expecting...."GTX". Decode of everything coming up....
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    VIN
    1FA = Ford vehicle manufactured in USA by Ford Motor Company
    B = active belts, no airbags
    P = passenger car
    28 = Mustang 3-dr hatchback
    M = sEFI H.O. 5.0L V8 engine
    9 = VIN check digit
    G = 1986 model year
    F = Dearborn Assembly
    325735 = 225,735th 1986 Ford scheduled for production at Dearborn Assembly
    Buck Tag
    MUSTANG = Mustang model line
    61B = Mustang 3-dr hatchback
    M = SEFI H.O. 5.0L V8 engine
    MO = moonroof (sunroof)
    3371 = body & paint rotations #3371
    1DD = Dark Grey Metallic exterior paint color
    DF
    ST
    AC = manual air conditioner
    04 = rear defrost, rear wing
    HB = heated backlite (rear defrost)
    S = speed control (cruise control)
    GTX = GT w/ hood graphic delete
    WD = power side windows (W), power door locks (D)
    MBW = manual Borg Warner transmission (5-speed T-5)
    01 = no hood scoop
    EL
    -A = Charcoal/Grey interior trim color
    EI = electronic injection (EFI)
    04
    1
    X
    2
    NLR
    4
    Build Sheet
    Line X
    860922 1246 = September 22, 1986 12:46 PM
    Line A
    Rotations Number - 0683 = trim & chassis rotations #0683
    Line - Z = Mustang model line
    VIN - P28GF325735 = [VIN decoded above]
    Body Type - 61B = Mustang 3-dr hatchback
    Body, Tops, Roof - 7 = Sunroof
    Ext, Paint, Body - 1D = Dark Grey Metallic exterior paint color
    Ext, Tutone - [blank] = no tu-tone paint
    Int, Trim - PA = cloth Articulated Sport seating (P), Charcoal/Grey interior color (A)
    Int, Deviation - [blank] = no interior trim deviation
    I.B. Color - A = Charcoal instrument panel color
    Type of Order - 2 = Stock order
    Region & District - 74 = Seattle district sales office
    Special Order - [blank] = not a special order
    Line B
    Emission Control - [blank] = no special emissions package
    Engine - M = SEFI H.O. 5.0L V8 engine
    Trans - 2 = Borg Warner 'T-5' 5-speed manual overdrive transmission
    Air Cond - M = manual air conditioner
    Engine, Tag Number - ZK341CA = unknown calibration (Z), Thermactor emissions with or without A/C (K), 5.0L engine (341), release level CA
    Transmission, Part Number - E6ZRFB = manual transmission (R) originally engineered for 1986 (E6) Mustang (Z), release level FB
    Seats, Type - 6 = Articulated Sport seating
    Belts, Color - A = Charcoal/Grey seat belts
    Line C
    Imm Block Heater - [blank] = no engine block immersion heater
    Line D
    Groups, Décor, Appear - B = GT package
    Electrical, Wipers - W = interval windshield wipers
    Electrical, Defroster - E = electric rear defrost
    Electrical, Audio, Radio - X = electronic AM/FM search stereo with cassette tape player
    Electrical, Audio, Spkrs - Z = four speakers with premium sound system
    Electrical, Lights, Light Group - V = visibility/light group
    Power Aids, Deklid Release - F = remote decklid release
    Power Aids, Locks - P = power door locks
    Power Aids, Windows - S = power side windows
    Glass, Tint - T = tinted glass
    Mouldings, Rocker - [blank] = no rocker moulding
    Air Dam - G = GT front bumper cover
    Road Abrasion - [blank] = no road abrasion coating
    Carpet/Mats - G = grey floor mats
    Console - C = console
    Luggage Rack - [blank] = no luggage rack
    Mirror, Outside - A = dual remote control mirrors
    Line E
    Battery - DC = heavy duty battery (54 amp-hr)
    Driveline, Speed-O, Metric - [blank] = no metric speedometer
    Driveline, Rear Axle, Tag Number - 201A = 2.73:1 axle ratio, Traction-Lok (limited slip) differential
    Suspension, Springs, Front, Left - MOL = O front left spring code
    Suspension, Springs, Front, Right - MOL = O front right spring code
    Suspension, Springs, Rear, Left - MID = B rear left spring code
    Suspension, Springs, Rear, Right - MID = B rear right spring code
    Pkgs, Hndlng - X = Handling Suspension package
    Line F
    Wheel Area, Wheel Covers - Z = wheel covers w/ embossed Ford oval
    Wheel Area, Wheels 1/2 - ZZ = 15" x 7" cast aluminum wheels
    Tires, Size - 22560VR = P225/60VR15 tires
    Tires, Color - [blank] = black sidewall
    Speed Control - S = fingertip speed control (cruise control)
    Front End, Steering Wheel, Type of Col - T = tilt steering wheel
    Hood Scoop - [blank] = no hood scoop
    Frt License Plate Bracket - X = front license plate bracket
    Line G
    Accent Stripe, Type/Color - GX = hood graphic delete, Dark Charcoal "GT" hood decal, Silver Metallic "Mustang GT" hatch/trunk decal
    VIN - 1FABM9 = [VIN decoded above]
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    That's Awesome! Thanks so much! WOW 2.73 gears stock.
    Can you post a pic of the door tag or is it unavailable?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    May 2003
    Roseburg Oregon
    How about a picture of the car too please .
    Dec 2002
    Greenville, SC
    Very cool. Thanks for posting and thanks Mick for decoding it
    1979 Mustang Cobra 5.0
    2P Red and 1C Black
    Stock never goes out of style
    Proverbs 3:5-6
    My Mustang Story
    I'll check at lunch never looked for it before. I assume its easy to find?
    It's on the rear face of the driver side door on hatchbacks and coupes. On convertibles it's on the driver side door jamb.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Door Tag
    F0074 = 74 lbs front accessory reserve load
    R0076 = 76 lbs rear accessory reserve load
    Exterior Paint Colors - 1D = Dark Grey Metallic
    DSO - 74 = Seattle district sales office
    Body - 61B = Mustang 3-dr hatchback
    Int Trim - PA = cloth Articulated Sport seating (P), Charcoal/Grey interior color (A)
    Tape - 1 = Dark Charcoal "GT" hood decal, Silver Metallic "Mustang GT" hatch/trunk decal
    R - 6 = electronic AM/FM search stereo with cassette tape player
    S - C = sunroof
    Ax - M = 2.73:1 axle ratio, Traction-Lok (limited slip) differential
    Tr - 2 = Borg Warner 'T-5' 5-speed manual overdrive transmission
    OO = front springs
    BB = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
