I been replacing my interior lights with LEDs and I was surprised to find there is an ashtray light.
Cant see it at all with th4e ashtray inserted but when I took the ashtray assembly out sure enough theres a light under it doing absolutely nothing.
The ashtray has 2 thin slits that I assume light is supposed to enter through. the light has a cover with a thin slit that I think was supposed to divert light into the ashtray. Mine points away from the ashtray slit. complete engineering failure.
I was wondering if I removed the cover and replaced the bulb with a bright LED would it actually light the ashtray?
Anyone else played around with this?
With the cover off you can se the ashtray light.
Attachment 106170
