Well done.
When I did a full 1971 Vauxhall Victor SL 2000 4 speed gearbox and clutch swap to my 1958 Vauxhall Velox, my teacher from the Power Board utlity company asked me I used a dummy layshaft to postion the clutch. I said no. He said, well you got lucky, but that I should always use one because they don't have dowels. The internal missaligment on in spervice parts often creats binding issues for clutch release. If using in service parts, the piolit bearing can be retreaved from the donar car using the I'm a Loafer Luva Shagger method...
https://www.youtube.com/watch?v=vhPFXJ4VYcM
Cleaned up afterwards.
from
http://vb.foureyedpride.com/showthre...-Release/page2
Ford drilled the crank the same, but the bearing repostions the manishaft.
You know that the SROD was i6 specfic with respect to gear ratios on the Foxes, although the ratios were the same as the F truck 4.2 v8 RUG.
Specfic I6 info is always ommitted, in typical anti I6 Ford bias. 4 cylinders are race cars, V8's are drag cars, I-6's are, what?
Your clutch quadrant upgrade is factory stock plastic. The pivot balls wear in, and are dicky and inconsistant. The whole process is pretty fidly, especially if your 200 pounds and over 6 feet. Its best to pull the seat back or whole seat off to conquer this task.
The stock MM replacment in alloy preserves the stock lever arm,
http://www.americanmuscle.com/maximu...-quadrant.html
The FRP's relacment doesn't.
http://www.americanmuscle.com/frpp-d...rant-8204.html
The reason for the lack of helps for alignment was that the manual transmision in line six was always a transitional engine. The 2.8 V6 was supposed to be the step up Fox option engine, so it was just a 2.3 trans. The V8's were always really well engineered. So the 3.3 was always out in no mans land, with first a 3 speed manual option for 1978, then a four speed, then an SROD upgrade which was such a total stop gap. A RUG Toploader internals with a trimline Tremec/Orion/BW case.
As
Mike1157 said in one of his posts, the whole beauty of the Fox platform was that Ford was able to shift the steering wheel and centre consol sideways between the years to fit everything in. Mike shifted his steering wheel to the Fox Mustang hand brake postions to equalise everything for a bucket seat car. The 1981 cars had tunnel mods to suit the T140, T-4, and there was a cross member change.
So you've made a 1981 part work well in your car.
