So I finally got my Scott Drake LED's in and working on my cluster. Not sure how I fried the original printed cluster but I got a used one and swapped it onto my cluster.
Anyway, gotta say I'm not happy and quite disappointed with the Scott Drake LED kit. I opted to go with the white lights since I thought going red would have left my interior half red and half orange. Would have been much easier if they made a kit for Stangs that have the stock color but anyway, the brightness of the white light washes out the orange color of the lens's. Big disappointment.
Also, I do recall reading other reviews saying the Scott Drake lights only flash forward and leave dead spots on the cluster. That is 100% correct. On the Speedo its shadowy between 35 and 55 MPH. I might have been able to live with that but on the tach its downright dark between 2000 to 4000 RPM and that a real noticeable flaw.
I see other companies that make LEDs that actually spread light forward and 360 degrees around. But with LED's they have to be 100% correct for the car and application or they wont work or wont work right. That is why I initially went with the Scott Drakes because they were specific for Fox Bodies.
As it stands I like the green lights Scott Drake gave for the directional, The red light they gave for the hi bean was horrible as it washed out the purple lens so I put a white light there and it still shows purple so I can keep that. The failure points are all the illumination lights on the cluster and the heater panel. The heater appears to take 1 light. I had extras with the kit so I put one in the heater panel and it lights exactly half the panel.
In addition to that I'd like LED's to replace the Trans shifter light that is so dull it almost looks like there's no light at all, and I want to LED the interior lights by the 2 kick panels and the 2 lights on the lighted rear view mirror and the console light as well.
This is why the Scott Drake kit is so lacking as it isn't complete and it leave you with a dual colored interior. Trying to use white to avoid that didn't work out so well . Anybody have other products to suggest for a uniform interior LED conversion that will give a bright white Map/Interior and uniform red or orange dash/console/heater panel?
