Results 1 to 25 of 35
    Nov 2014
    Grand Rapids, Mi
    Default Cleaning up the old 351W
    Since the engine has to come out anyway, and it's closing in on winter, I figured I might as well give the old girl a fresh coat of paint. She was first painted almost 20 years ago, so it's over due. A re-paint, and a sweet aftermarket serpentine pulley kit are in the works. Name:  image.jpg
Size:  116.6 KBName:  image.jpg
    Cool... what's with the front dip stick with a rear sump oil pan?
    Nov 2014
    Grand Rapids, Mi
    Only timing cover I had at that time.
    What are the specs on this beast?
    Nov 2014
    Grand Rapids, Mi
    Ported Performer RPM heads 202/160's, and intake, with IIRC, a 296/302 duration cam. With the 1 3/4" full length headers, it dynoed at 452 at the flywheel. I've since gone with 1 5/8" shortys after having tranny trouble and after a couple of times of pulling the trans, I said screw that. I'll eventually put the full lengths back in at a later date. The drag days are gone, so if it dropped to 400ish, who cares.
    Rock'n'roll
    Nov 2014
    Grand Rapids, Mi
    Now it's time to rob the old 5.0 timing chain cover. I have one from an SN95, but don't feel like messing with an electric fuel pump right now. Name:  image.jpg
    Nov 2014
    Grand Rapids, Mi
    Well, scratch that idea. Three broken bolts later, it came off. After examining the covers, they appear identical, with the exception of the dipstick hole, and the timing marker. That worried me. So, I'll clean up the old cover, tap the dipstick hole for a pipe plug, and call it good.
    Oct 2014
    Calgary, Alberta, Canada
    That's how I plugged the dipstick hole in my timing cover.
    May 2016
    Lake City Pa 16423
    The cover for the sn95 uses a different water pump and it's shorter as well and the pump pulley won't match up with the crank pulley.
    Nov 2014
    Grand Rapids, Mi
    After a few hours of using a wire brush, it was time for spraying the intake with Aluma Blast. This should protect the intake for a long time. I hit the new water pump as well. Just waiting on the timing chain cover to come back. In the meantime, it's time to spray the heads. I'll also add, I'm thinking of spraying the block black as I think with the aluminum pulleys, and nice shiny aluminum, it will really stand out. Thoughts?Name:  image.jpg
Size:  110.3 KBName:  image.jpg
    May 2014
    Royal oak Mi
    Aluma blast thanks for post
    I think it will go good together in fact I'm going to do the same on mine and was not sure about the intake until I saw this
    Good luck
    Mar 2014
    Omaha, NE
    I say go for it! IMHO.....the green block is hideous, especially with all of the nice things you are doing to this ride.
    Brock
    Your engine, your choice..
    Keep it clean, repaint it black if its a Windsor 351, paint the rest of the car in Renault green....
    Care of http://hotlaps.net.au/greens-tuf-xe.asp
    http://hotlaps.net.au/images/greens-tuf-xe.jpg
    And another on a proper, righteous racer....a little black 5.0 hidden in the greenery
    No way, a black T roof GT with 5.8 badges, its perfect already.
    Green is the color for that 5 point Ate Wubble Uwe engine for sure!
    Nice ride.
    I'm a hood blister fan...
    http://www.theroaringseason.com/atta...chmentid=20984
    Nov 2014
    Grand Rapids, Mi
    Well, the original 83 timing cover is back on. I gave it to the BIL, and it came back clean, and all three broken bolts came right out. It's awesome having someone that deals with this type of stuff everyday. Name:  image.jpg
    I'm going to pick up some Aircraft Stripper, and strip the block down, and am torn between POR15, and good old primer, and high heat rattle can paint. The paint on it lasted for 20 years in just a barn. I now have a temp controlled environment so it should hold up just fine. Heck, I put new rotors on last February, and they still look new.
    Jan 2003
    lansing, mi
    I had to buy a new timing cover for mine. It came out of an Engine Quest box. I think you're better off using an oem cover. The casting flash in the water ports was pretty bad, I basically did a port job with a carbide burr and some sanding rolls. It also has the front dip stick hole that I'm going to pipe tap 1/8" npt and plug.
    Right now is probably a good time to throw a new set of valve springs and valve seals in it. I'd probably be inclined to take a lot at the bearings too. One of these would probably look pretty killer with the new serpentine setup too:
    https://www.summitracing.com/parts/p...view/make/ford
    Cale
    Nov 2014
    Grand Rapids, Mi
    Let the stripper do the work. Goodbye green. Name:  image.jpg
Size:  101.4 KBName:  image.jpg
    Jan 2003
    lansing, mi
    Kleen strip huh? I'll have to try that. I haven't had great luck with Tal-strip aircraft stripper in the past.
    Cale
    Nov 2014
    Grand Rapids, Mi
    I brushed it on, walked away, and the stuff melts off. I did do it twice, as there was a little stubborn paint left. Then I cleaned it, and shot it with Easy Off and wiped the cast iron clean. I'll follow it up with brake cleaner, minerals spirits, and my final prep of alcohol.
    I'm just torn on Black, or Red paint. Leaning black.
    Black or dark Ford Blue.
    Mar 2014
    Omaha, NE
    I second this answer. I will probably just go black with mine when I redo it, but then again I have a tan car so I'm limited in my choices without making the motor look like an afterthought eyesore.
    Brock
    Mar 2014
    Omaha, NE
    Am I looking at that right and the oil filter mating and internal filter oil contact area is also painted? I dunno about you but I don't think I would personally paint that area moving forward. Seems like a bad place for paint........
    Brock
    Nov 2014
    Grand Rapids, Mi
    Making some progress. Hard to do when you have to stop every 5 minutes and beat some kids. I know ya'll understand. Name:  image.jpg
    You forgot screaming wife too
