1986 notch 3.8 v6
The buck tag was missing so I just got the door tag.
1986 notch 3.8 v6
Matt
Thanks! Added to the DB.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
VIN
1FA = Ford vehicle manufactured in USA by Ford Motor Company
B = active belts, no airbags
P = passenger car
26 = Mustang LX 2-dr coupe
3 = 3.8L V6 engine
0 = VIN check digit
G = 1986 model year
F = Dearborn Assembly
153735 = 53,735th 1986 Ford scheduled for production at Dearborn Assembly
Doro Tag
Date - 10/85 = October 1985 scheduled build
4075 lb/1848 kg = gross vehicle weight rating
2206 lb/1000 kg = front gross axle weight rating
1993 lb/904 kg = rear gross axle weight rating
F0254 = 254 lbs front accessory reserve load
R0194 = 194 lbs rear accessory reserve load
Exterior Paint Colors - 9L = Oxford White
DSO - 23 = Memphis district sales office
Body - 66B = Mustang LX 2-dr coupe
Int Trim - CB = vinyl seating, low-back front buckets (C), Regatta Blue interior trim color (B)
Tape - Q = Medium Academy Blue paint stripes
R - 7 = AM/FM stereo cassette
Ax - 8 = 2.73:1 axle ratio, non-locking differential
Tr - C = C5 automatic transmission
CC = front springs
GG = rear springs
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
What a shame that looks pretty nice from the pictures.
Keith formerly STLPONDS
'79 V8 coupe in the works!
Dang!!
Absolutely no way that would be in a boneyard up here in the rust belt. That body would be on Craigslist for a couple grand, easily.
And I've been looking for a spare nose and rear bumper for my 86... can't justify the trip to AR though.
Have
86 Coupe LX Conversion 5.0 5spd
70 Mustang Conv. My 1st car. Still have it.
70 Ranchero 302 Auto
07 Focus daily driver
Totaled
70 Ranchero 351C Auto
85 Coupe 1 of 62 Sand Beige
