Let me start by introducing my self.
Cell for text is 3362579101
********If you don't see it just ask*********
All items located in Roaring River NC 28669
For any items you may can pick up I am 45 miles East of Boone NC and 45 miles West of Winston Salem NC, about an hour north of Charlotte NC
Here are the two cars I pulled parts from.
79 Coupe Ghia
1980
Parts off and currently available for sale.
Ghia blue map pockets $40.00
Wood grain bezel $20
79 1/4 Window coupe sail panels (need sanding or stripping but all studs intact and no issues other than exterior paint $30 set
79-86 1/4 Window glass for hatchback drivers side $20
79-86 felt retainers $3 each a few included (cheaper the more you buy)
Mustang Coupe Chrome 1/4 window coupe trim $20 each
Coupe 79-86 drip rails (**Drivers side only** is all i have left $50)
79 tail light housing RH Side only $ 25
79-84 4 or 5 speed Manuel pedal assembly ****Non Quadrant**** style $75
85-93 5 speed manuel pedal assembly Quadrant style $75.00
79-93 RH Passenger Manuel Window Regulator $35
79 complete window glass door post guides RH and LH $55.00 set
4 speed clutch cable cover plastic OEM $10
84 5 speed Speedo cable $15
79 Turn Signal/wiper Switch and horn $20 each or $35 for both
80 Mustang turn signal switch $15
80 Mustang wiper switch $15
80 wiper motor $15
79-93 Coupe rear window $75 (non defrost) with defrost $100
79-93 Coupe rear glass/window trim 4 pc kit $130.00 (in good shape, but would prob want to paint) **Also have individual pcs***
79 a.c. condenser was in good shape still holding pressure $30.00
79-86 interior side head liner trim $10 each
79 Mustang coupe seat belts , Blue in color, Fabric pretty clean, chrome has rust still work, complete set $25
2 4cyl 81 under hood items as I will be gutting and cleaning up engine bay for 8cyl swap
79-86 dash metal frame needs blasting $40
84 duct work $40 AC car , complete
79-86 blue arm rest in good shape $30
hi and low horn set RH and LH $15
79-86 Blue Coin tray Condition okay $10
1979-1982 Front Bumper Cover $75 (pick up only)
1979-1982 Front Bumper Cover $30 (shape okay)
1979-1982 Headlight panel $40 (good shape)
1987-1993 Headlight Panel $50 (excellent shape)
1987-1993 Factory Hood $50 (white color, Good shape)
1987-1993 Factory Hood $30 (needs paint, Good)
1979 Door Panels Blue Need stripping $50 Set Useable shape
1979-1982 Coupe interior Quarter panels Needs paint/stripping nothing broke $40 Set
1979-1993 Door Glass RH or LH Factory OEM $15 Each
1979-1986 Dash Hull good shape $50 No pad (Carmel Color)
1979-1986 Console Frame $20 (blue good shape)
1987-1989 Dash 3 available decent shape $40 Each
1994-1995 Moser Axles no Studs $150
1987-1993 LX cloth seat frames front only $50 set
1981 Seat Frames and cushion $50 obo
1989 Rear Convertible quarter panels (Complete back half of car Shell only) Great home decor project $50
1987-1993 Convertible Trunk Springs $20 Set
1979-1989 Tilt Col with key $100
1987-1993 Rear Coupe/Convertible trunk latch $20
1996-1998 Cobra 4 valve Throttle Cable Bracket $20
****1989-1993 Mass Air stock OEM hoses, short lower and upper, with MAF bracket No MAF included $30
1979-1995 Mustang Lake wood Drive shaft safety loop $15
1987-1993 Inside passenger side door handle, Grey excellent shape $15
