So the title pretty much says it all. Running a t3/t4 turbo and it has been burning oil at a pretty high rate(bout a qt every 2 tanks of gas). Already swapped turbos once. Did a compression check when i first got it and everything seemed to be within the correct parameters. Just did the pcv delete and noticed that it is basically spraying oil out of both filters I installed. I have the larger oil drain line from stinger ordered, hoping this will remedy my problem, but barring that I'm at a loss and I would hate to do a whole motor swap seeing as this motor has been super reliable aside from the oil issue obviously.
Any help/ideas would be greatly appreciated.
