Results 1 to 3 of 3
    Default Pacesetter long tubes on an 83 3.8L
    Haven't seen a post that clarified this, but did see one person with pacesetter shorties. Will 94-whatever pacesetter headers bolt onto an 83 and fit in the compartment without any major modifications? The guy who posted pics with the shorties didn't say anything about modification, and doesn't seem to be actively using the site, so maybe one of you guys knows before I end up buying a set and having them not work?
    thanks
    Oct 2011
    Nampa ID 83686
    I've been absent from the site for a while. To answer your question...I'd say the '94s would not work without some modifications. It might be worth it to look at Pacesetter's website, (http://pacesetterexhaust.com/headers-for-cars.aspx#ford), to see for yourself. This is what I found:
    Ford
    Excort ZX2 97-03 2.0L 1-1/2" 2-1/2" G7169 70-1168 72C1168
    Focus ZX3 00-03 2.0L 1-1/2" 2-1/2" G7169 70-1169 72C1169
    Mustang 86-93 5.0L, shorty 1-5/8" 3" G7063 70-1067 72C1067
    Mustang 01-04 3.8L V6 1-5/8" 2-1/2" G7077 70-1077 72C1077
    Mustang 05-10 4.0L 1-5/8" 2-1/2" G7387 70-1073 72C1073
    Mustang GT 94-95 5.0L, shorty 1-5/8" 2-1/2" G7322 70-1075 72C1075
    Mustang GT 05-10 4.6L 1-5/8" 3" G7328 70-1074 72C1074
    Mustang Additional Mustang Performance Systems
    Pinto 74-80 2.3L 1-1/2" 2-1/2" G7051 70-1064 72C1064
    These are the design notes found on their website:
    1. Flanged Collector
    2. Slip-fit Collector
    3. Hook-ups for smog & engine management sensors where required
    4. No smog or engine management hook-ups O2 sensor fittings when required
    5. Comes with collector reducer. Fabrication required to hook to stock system
    6. Comes with extension to connect to stock system. Fabrication may be required
    7. Fits cylinder heads with evenly spaced exhaust ports
    8. Fits cylinder heads with paired exhaust ports
    9. Catalytic converter must be relocated
    11. 50 States legal (C.A.R.B. legal, E.O. available upon request)
    12. Replaces stock exhaust manifold. Bolts to stock down pipe.
    13. Long tube header
    14. Shorty header
    15. Retains catalytic converter in stock location
    16. Y-pipe available to connect to stock system
    17. X-pipe available to connect to stock system
    18. H-pipe available to connect to stock system
    19. Extensions available to hook to stock system
    20. Will not fit angle plug heads
    22. Y-pipes 82-1176, 82-1177 will not fit 6.0L
    30. Includes catalytic converters
    Sorry you had to wait so long for a response, but I hope this info helps.
    Craig "IDMooseMan" Peters
    Buyer/Seller Experience Link
    Build Thread
    Good afternoon, the stock shorty headers from the 94-98 3.8 where a direct bolt on replacement to the cast iron ones on my 1983. I did have to weld up the O2 sensor holes, but you could just leave them in and they would have fit between the frame rails. No modification to original Y pipe or catback system required. The is a picture early on my project log, which I should probably update at some point as I've done a few updates since.
    But seeing as stock was a good fit, it is within reason that aftermarket would also work.
