Sent from my SGH-I337M using Tapatalk
VIN
9 = 1979 model year
F = Dearborn Assembly
02 = Mustang 2-dr coupe
F = 5.0L V8 engine
351873 = 251,873rd 1979 Ford scheduled for production at Dearborn Assembly
Door Tag
Date - 07-79 = July 1979 scheduled build
GVWR - 3871 lb/1755 kg = gross vehicle weight rating
Fr GAWR - 2074 lb/940 kg = front gross axe weight rating
Re GAWR - 1817 lb/824 kg = rear gross axle weight rating
F0127 = 127 lbs front accessory reserve load
R0081 = 81 lbs rear accessory reserve load
Exterior Paint Colors - 1G = Silver Metallic
DSO - B1 = Central Ford of Canada district sales office
Body - 66B = Mustang 2-dr coupe
Mldg - 73P = Black bodyside moulding w/ Argent stripe inserts
Int Trim - BD = cloth & vinyl seating, high-back front buckets (B), Medium Red interior color (D)
A/C - [blank] = no factory air conditioner
R - [blank] = no factory radio
S - [blank] = no sunroof
Ax - B = 2.47:1 rear axle ratio w/ non-locking differential
Tr - W = C4 automatic transmission
ZZ = front springs
FF = rear springs
Buck Tag
MUSTANG = Mustang model line
F = 5.0L V8 engine
1328 = body & paint rotations #1328
1GG = Silver Metallic exterior paint color
R = Medium Red interior trim color
ST
HB = heated backlite (rear defrost)
RA = road abrasion coating (lower bodyside protection)
LHM = left hand mirror
WQM
1 = no hood scoop
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
It had a dealer installed AM ford radio and center dash speaker accessory with a factory woodgrain radio bezel. The antenna was a cheap aftermarket one as the screw holes were never used for a factory one which I found odd.
Wow sounds like a freaking awesome car! No ac.. cool
Eventhough I just got it, I have it for sale. It wasn't as described.
88 Turbo Coupe auto
88 Turbo Coupe 5spd
79 Fairmont Futura 4.6
80 Capri 5.0/5spd project
79 Pace Car 5.0/5spd project
86 GT conv 5.0/5spd
That sucks. Long way from you but here's one I just saw.
https://greensboro.craigslist.org/cto/5723177293.html
It's fairly close to me. Let me know if I can help.
88 Turbo Coupe auto
88 Turbo Coupe 5spd
86 GT conv 5.0/5spd
Build sheet found!!
Can you email me a higher res pic? Should be able to decode some of it.
Click HERE to send me an email through the site and I can respond with my email address.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Also, where did you find that sheet? So others know of the secret hiding spots.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
What is wrong with the condition of the body.
Chassis, I found my build sheet behind the quarter plastic , passenger side in my 84Gt.
It was found under passenger side carpet. Tape still sticky...lol
I'll try to get a higher resolution photo to you.
Any progress on the build sheet pic?
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
I hope this is better as I sold the car.
