If there are 96 and you have any plans in the future to go to an aftermarket K-member it might call for 96 so if you see this grab them too.
watch yourself - those coil springs are dangerous! Once you put a jack on the A arm to relieve the pressure on the strut bolts and pull them you're committed for sure. At least run a chain through the spring and a arm and connect it to itself. Or preferably use a coil compressor...
