Page 1 of 59 1231151 ... LastLast
Results 1 to 25 of 1465
    Default My '83 GLX T-Top Coupe Junk Yard Find
    So, for $1000 I found this '83 GLX coupe at the junk yard I was searching for parts for my '86 GT.
    I just finished paying for it and hopefully will have it registered within the next two weeks. I will make this a beautiful car one day, but for right now, I just want it to run. It has an Essex V6 and the jy owner said it ran when it got there 15 years ago.
    I will spend about $3k on it to make it a comfortable driver. No major modifications, no paint, just reliability first.
    Pictures:Name:  image.jpg
    FEP Supporter STANGMAN116's Avatar
    Mar 2013
    DENVER CO, the 303
    Amazing find!!!!! Car looks solid!!! Congrats
    Lots of potential there. Good luck with it.
    83 Mustang GT , A5 5 speed, 31 spline Cobra rear, LMR TRX, 302 11r 190 heads, Buddy Rawls custom cam
    86 Capri , 342 stroker , AFR 185 heads, Track Heat intake, 3.73 gears
    FEP Senior Member rodster's Avatar
    Feb 2006
    Allentown, PA
    Nice find! Looks solid and I'll be interested in seeing your progress, keep us posted!
    Thanks y'all. It'll be interesting, I'll guarantee that. Long ways to go on this one. I paint car for a living and kind of think I want to modernize the blue with Kona blue. A modern version of the original, so to speak.
    Btw, the floor is solid! My red car needed new floor pans and patches welded in several places. Kind of wierd finding a t-top with the pans as nice as this one.
    FEP Member 9D83's Avatar
    Nov 2015
    'oer the border
    Quote Originally Posted by 4eyedfoxdriver View Post
    Agree, air, pwr locks, cruise, T tops and 3L paint-nice!
    Looks like a real sweetheart, thankfully getting a second chance.
    1983 Mercury Cougar 3.8L LS
    1981 Mercury Marquis Brougham
    1971 Mustang Fastback
    1974 Pontiac Luxury LeMans
    Nice score!
    A lot of cool vehicles in this shot, the Jeep pick-up with the Fox hatch leaning against it, the '65ish Ford pick-up behind it... I also see a 1st-gen Econoline and that '70ish T-Bird. (Landau?)
    Quote Originally Posted by grabbergreen84 View Post
    Nice score!
    To the immediate right of the jeep pu, there sits a '79 turbo four mustang, all original with the TRX package. To the right of that one is an '83 convertible, to the right of that one is an '85 SVO.
    His yard is inactive, it was his father's yard. He likes four eyed mustangs though and has very few '87-'93 mustangs. Maybe 20-25 four eyed though. My coupe is one of the newer additions and it has sat there for fifteen years.
    If you could, and it's not too much trouble, would you please get pics of all of the door tag and buck tags on all of the Foxes there? I would like to add them to the database. Thanks.
    Buck Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    I'll try to get that for you. This yard isn't active anymore, so the owner is a little sensitive about some of the cars. Plus he's only out there one day a week. It won't be immediate, but I'll get them as I can.
    Plus, I can't open the driver's door on some of them because of growth around the vehicles.
    Default Getting the old boy running
    So, I'm finally going to do something with this car. The plans are to basically make it a stock glx that is running for now.
    I recently found two '83 convertible doors on Craigslist for $230. I only need the passenger door since the original is split along the seam along the front edge of the door and has a fairly significant amount of bodywork to be done to it. Since I found these doors that are in much better condition, I'll use the passenger door. I have already gutted the door and will pull out the small dings in it on Monday. I will have it media blasted next week, primer it block it and go ahead and paint it.
    I will paint the car Kona blue since it's similar to the original, just an update with pearls and cleaner blues.
    The car over the next month will get a complete fluid change, to include the brake fluid. New filters, brakes, pretty much everything.
    I have already purchased new mass back carpet, dashpad, and seals for the t-top. I will be getting a new headliner, tires and more.
    For now, it will just be getting a set of cheap seat covers, though I am trying to be able to swing new seat foam. If I get new foam, I'll wash the original seat covers just to get rid of the "been sitting fifteen years" smell.
    I'll include pictures of the "new" door, it's moulding and the one from the new driver's door are in great condition too. Yay!
    So, after sitting in the sy for the last fifteen years, the old boy will be running shortly.
    BTW, I have a nickname for my blue car to simplify things. His name is Robby (short for rusty old blue bastard)Name:  image.jpg
Size:  78.3 KBName:  image.jpg
Size:  103.7 KBName:  image.jpg
    Feb 2006
    Allentown, PA
    It will be so cool to watch this car come back to life!! Thanks for sharing.
    Default So I Went to Oriellys for My Truck and This Followed me Home
    I was getting new brake pads, discs, flexible hoses and fresh brake fluid for my truck and I accidentally came home with extras. Got new coolant hoses, belt, carburetor rebuild kit, and a new fuel pump for Robby.Name:  image.jpg
Size:  125.9 KB I've got to stop spending money off of this check!
    FEP Super Member tORMENtOR's Avatar
    Oct 2007
    Bethlehem,PA
    Nice find, looks like a good start for a build.
    Current Stangs+
    84Gt (9W) T-top 347EFI
    http://www.foureyedpride.com/content...984-Mustang-GT
    84Gt(1E)Hardtop Turbo
    84Gt(1C)Sunroof 306
    Default Boxes from Heaven
    Got the first box in todayName:  image.jpg
Size:  77.6 KB New rug for Robby!
    I dropped off the passenger door with the media blaster today. I should have it back by Thursday and will get it in etch primer real quick. Then I'll smooth out the bottom of the door and get it in regular primer. It'll sit through the weekend, then I'll block it out, seam seal it and paint it Kona blue. We have a new clear coat at work that I can't wait to use on this car. So maybe by next Friday the door will be painted.
    Friday I can get back into the sy. I'm going to bring back as many panels as I can, the hood, fenders, deck lid and bumpers. They'll all be going the same route as the passenger door.
    All that will be happening for a couple days is for new boxes to be on my doorstep when I get home from work. That's a nice thing to come home to.
    Default Kona Blue
    So, I've been busy.
    I had that red door media blasted and I repaired the dents in it and painted it Kona blue.
    Ive also retrieved both fenders, front bumper and deck lid. I've had them media blasted and have finished the body work on the left fender and am close to the final blocking of it. I may have it painted this week.
    I got hit with a $2000 marching band fee for my son, this delayed some of the action on the car.
    I have purchased a new mass back carpet, dash pad, headliner, new seat foam, new seals all around, and all sorts of stuff for the engine. The carburetor is being soaked right now and I should reassemble it this weekend.
    Ill include a couple pictures of the door, the rest of the panels you'll just have to imagine bare metal parts. I have etched primered and surface primered the parts I haven't got to the bodywork stage on yet just to keep the rust monster at bay.
    Anyhow, picturesName:  image.jpg
Size:  59.6 KBName:  image.jpg
Size:  73.8 KBName:  image.jpg
Size:  118.1 KBName:  image.jpg
Size:  168.1 KBName:  image.jpg
    FEP Power Member Bryan Knebworth's Avatar
    Sep 2010
    Lexington, MA
    Sharp color, not unlike the original '83 Blue
    Feb 2006
    Allentown, PA
    Love the color and the door looks straight as an arrow! Thanks for the update. Looks like you have been busy!
    Thanks, that's what I was hoping for really. Just a little modernized with pearls and a little bit cleaner blue.
    I probably spent about eight hours straightening it, you know how the lower part of a fox door can be. Plus I had to weld the trim holes in the top of the door. It was a door off an '83 convertible.
    Maybe tomorrow I'll have a picture of the left front fender painted as well. I just need to do the final blocking of it.
    Ive decided to paint all of the panels off of the car. Once I have them all off, I'll get the car towed to where I'll be able to work on it. I figured it would be much easier to get the engine running and redo the interior without any of the panels on it, if for no other reason than installing the new headliner. I won't worry about the fenders either while getting the engine running. Much better to me that way.
    BTW, I'm being very precise in my painting of these panels to hopefully prevent any mismatch between them once reassembled.
    FEP Super Member
    May 2003
    Roseburg Oregon
    I need the passenger fender molding behind the wheel , with that same red if you find one .
    Feb 2006
    Allentown, PA
    I'd say that's an excellent plan.
    Jan 2006
    Western MA
    Cool project, the color on the door looks phenomenal....
    JT
    1986 SVO Mustang - 1C
    Man, your post is blowing up! Nobody said a word about my $700 83 glx convertible garage find. ;(
    But on to the topic at hand, as far as I've noticed, no one has mentioned something amazing about this car: We're looking at a glx notch back with t tops! There were maybe 300 of these made. 1000 or so total t-top notchbacks from 82.5-83, but most of them were LX or L. That is an awesome find. Even if the poor little essex takes a lot of modding to be a powerhouse.
    On a side note: I went to union HS from 00-03. What part of Tulsa do you live in?
    Feb 2006
    Allentown, PA
    Quote Originally Posted by Thegreatoscillator View Post
    Did you ever post anything about it here? I don't recall seeing anything?
