That full floor looks like a big project. I’ve done halves but never a full pan. Good luck.
1986 SVO Mustang - 1C
What a day......I got the old floorpan completely removed. Would you believe I cut all of those spot welds out with one HF spot weld cutter bit?
There are a couple areas I'll need to patch on the rear floorpan. First the driver's side passenger foot area, it's a bit rotted out
Then a little side ways from that, the vertical area that the eb bracket welds to.
I'll use pieces of the old floorpan to fix these areas.
Whilst the old floorpan is out I might as well straighten out the pinch welds along the rockers. The passenger side is a bit ugly!
You're a better man than me, the last few days up here it's been so hot you could cook a turkey in your pants. I cleaned out a grain bin (even hotter in there). I haven't had the energy for extra work, especially not rusty dirty work
While not a common occurrence I have cleaned bins before to help an uncle...years ago...on a somewhat hot summer day. I have not tried the turkey in the pants thing before Or heard that expression before
BTW Dave, I am amazed at what you are doing. From afar you make it all seem so easy! Bing, bang boom, floor out!
In your garage!
Wilma, the Floors dropped out of the Fred Flintstone car.
Now its perfect Dave!
Dave, do the new floorpan lips fold up like the original ones or down along the rockers? I know the first gen mustang repro floors used to be bent the wrong way. I think they finally got it right over there in China eventually and now they fold up like they are supposed to.
I apparently have done enough rust repair in the last 30 years, because I look at what you have done and keep thinking I probably would have walked away from that car the first day I saw it. Though I have to admit I am a bit jealous of you having a super nice ttop coupe in the end. I'm working on a 68 mustang coupe right now that is down to the shell that I did a bunch of metal work on. I finally am to the block sand and filler primer stage. Would like to have it in paint by end of summer or early fall. So I know what all of this is about. Huge huge job not for the faint of heart.
The bend on the rocker edges goes upwards like the old one. What a pita it would be if they went down!
This is one of those times that I'll live with a chinese product. I'm very much a Buy American kind of guy.
Funny you mention walking away, I wouldn't do this for anyone else's car unless they paid me a whole lot of money. But I really like doing this stuff in this situation. It's my hobby that I enjoy. Not just the end product, the process is every bit as much fun for me too.
The yard owner from where I found Booger recently got a '69 fastback that he's trying to sweet talk me into helping him on. I may, he's a really good guy.
I can't wait to be at the final stages of primering and blocking, that's a long way off for me. I still have it in my head I'll have the eb/front end painted the first week of September.
I hope your project turns out well.
I'm not sure what I'll do here.
The type of sfc's isn't the question. It's when I should put them in.
The few sets I've installed have been on cars that had their drivetrain in them and the weight of the car on the wheels.
Do y'all think I would have a problem with installing them even if I have Booger on all four wheels and yet not have the weight of the drivetrain in the car?
I wouldn’t think it would be a problem. You’re working with a shell. Everything will be properly aligned during the balance of the build including the doors.
I’m really at the point to choose the style of SFC’s I want. I still like the idea of through the floor SFC’s. I just hate the idea of cutting up a new floorpan!
Just go with MM full length. Through the floor is totally unnecessary! The SFC are not the lowest point with the MM connectors anyway.
What erratic50 said. Besides, it would make it hard for the next guy to return it back to stock.
So, today. I did a couple things.
First I cut out the rotted sections in the front of the rear floorpan.
I used the trimmed sections to make cardboard templates to transfer to some of the old floorpan. I trimmed out those pieces and welded them in.
I welded in the eb cable bracket and coated the bare metal with some etch paint for now.
I put the new floorpan in to see what I have to trim. It needs about an inch taken of the front (still need to put the new holes for the eb handle too.
Next move is the subframe connectors, I'll be doing a ladder system with a jacking bar along the pinch weld. I'm out of spending money, sooooooo.....
I'll make my own. We'll be covering that this week.
Hey Trey, is there any good way to smooth the rocker pinch weld?
Right now I'm thinking of hammering it as flat as I can and filling it somehow, wether bondo or some other way.
That's about the only way that works for me. Sometimes some additional welding will for fill in helps to limit the filler. I personally like Evercoats All Metall filler for something like that, but even the Rage or Rage Ultra will probably work fine.
The Floor looks good, now that you have it all figured out, when are you going to make the trip down to Round Rock and fix the RS for me!
Hint of advice on subframe connectors, You want to support the car at three point as it sits right now. The best is usually a pair under the rear axle and then one center up front under the K member. I know your K member is out, but you may want to consider at least temporarily bolting it in or at least use a piece of square tubing and support that with a jack stand. That will allow the car to sit as level and square as possible while you install the SFC. Good Luck!
Trey
Thanks Trey. I'll probably throw the crossmember back in there for this stage.
Yeah, maybe some filling with the welder and all metal for the rocker. I like to have that smooth.
BTW, the floorpan fit easily through the windshield for those wondering how the hell to fit it in your car.
It always seemed to me that the perfect way to put sfc on would be to put the car on a frame machine to make sure the car is square and straight and weld on the connectors while mounted on the machine. It wouldn't matter what weight is on the car then would it?
That's a favor I've been waiting on... asking my buddy to strap my car to a frame machine at his shop on a Saturday so I can put sfc's on mine.
I did the SFC's in my car the without the drivetrain in it also. Do it like a cage install. Make sure you have the tub level and very well supported. I used 4 jack stands and 4 RV leveling jacks to support it. Probably overkill but better safe than sorry. Good luck, looks good so far!
Dave, where did you source that complete floor pan from?
1984 Mustang LX
302, Holley 4bbl 600 vac sec
B&M C4 R servo
Shorty Headers
MSD Box and Coil
Scorpion Roller Rockers 1.6
Crower Cam 472 112 seperation
Chetah Shifter
Performer RPM Intake
Carter Electronic Fuel Pump
Accel Eletronic Dizzy
Sorry not much has been done the past couple days.
I got a new job offer and I have officially taken it and start next thursday.
This is a good thing, it pays considerably more. More money for a certain Booger, if you know what I mean.........
Tomorrow night I have to fill out paperwork and Friday I have to make a urine donation.
I will probably do a couple things though still. I want to make my subframe connectors this weekend, so I have to get all of the tubing maybe tomorrow night.
