1984 Mustang Gt Turbo. 49,367 original miles. Original paint with the exception of the hood stripe and the top of the driver side door. Paint is in excellent condition for its age. Car is rust free. 2.3 turbo engine, 5spd. I have owned the car for 2 years and put 10,000 miles on it. I brought it back to life. It sat in the previous owners driveway for 6 years not being driven. NEW PARTS - 3 inch downpipe and exhaust, spark plugs, spark plug wires, timing belt, water pump, thermostat, O2 sensor, Kirban adjustable fuel pressure regulator, 255 Walbro fuel pump, fuel filter, distributor cap/rotor, Kyb shocks front and rear ,eibach springs, caster camber plates, radiator, front/rear brakes (rotors, pads ,drums, wheel cylinders,wheel bearings) steering rag joint, headlights, tps and iac sensors, reproduction 93 cobra wheels, dash pad, Pro 5.0 shifter. Tires and wheels have less than 3,000 miles on them. Engine has been upgraded to SVO Mustang specs. 35 lb injectors, large vam, LA3 chipped computer. Rebuilt turbo with E6 manifold. Custom intercooler set up with turbo coupe intercooler and has blow off valve. Gillis boost controller. Boost is set at 14 psi. Runs and drives great. The convertible top needs to be replaced, bottom of driver seat is split, valve seals should be replaced . I have all the original parts, window sticker, manuals, and dealer paper work from the original owner. Also have brand new ford valve seals that will go with the car. Please call or txt 484 684-8235. I am located in Downingtown, PA. $6,500.00 obo. I also have it listed on Craigslist in the Philadelphia section.
