Ball Joint Spacer set for the SN95 to the 79-93 Fox body a-arms and ball joint. the are Laser cut from A36 High carbon plate steel.. not cast iron or stamped from cheap scrap steel like a washer. perfect fit for the 5 lug sn95 to fox body front spindle swap .. no need to use stacked up flat washers or thin Ebay spacers ... these are Painted gloss black or can send them unpainted. $12.95 per pair shipped including paypal.. ...... thanks
