Results 1 to 11 of 11
    Default T5 Rebuild or Replace?
    Are there codes to consider on the T5? In the "matching numbers" sense? I've developed a 3rd gear vibe that spells impending doom. I've used an out of state reliable source for T5 remans in the past but they want the core. I can have the Predators T5 rebuilt locally but it's more expensive and I've had to have (2) pulled back for warranty work using (2) different local sources. I really favor the out of state reman option. So the million dollar question is whether my Pedator T5 has codes to consider.
    65 Fastback 302/T5
    82 Mustang GT
    84 Mustang Predator GT302H 4S-119
    Barboursville, WV
    The t5 in your car will have a code that tells the date. No other visual clues that I know of. If you're worried about having a "correct" t5, just swap the tag over. Get a world class t5 and never look back. If yours is original, it should be non-wc.
    Barboursville, WV
    No markings on the case that identify it. Just a tag attached to one of the bolts.
    Barboursville, WV
    I may have given you wrong info. Some info is available in the casting numbers (although not specific to your particular car, it can be somewhat date-coded).
    http://www.pro-forceperformance.com/...tification.htm
    So non WC and a 2.95 gearset it seems
    65 Fastback 302/T5
    82 Mustang GT
    Original case has the last eight of the VIN stamped on it.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    That doesn't surprise me. Ok rebuild it is then.
    65 Fastback 302/T5
    82 Mustang GT
    FEP Power Member 02Z06's Avatar
    Jun 2006
    Austin, TX
    There are guys around here that will rebuild a T5 for around $500, so usually it's about half the cost of buying a new unit. If there are local mustang boards to you, post up and ask if anyone locally rebuilds them. There's usually someone that does it as a side business, apparently it's not super difficult (although I've never tried it!)
    Chris Lott
    '81 Cobra T-Top - Black
    '85 Dominator GT - Black, 24k miles
    '85 Predator GT302R #150R - Light Regatta Blue
    '85 Predator GT302 Convertible #119 - White w/blue stripes For Sale
    '86 Texas DPS Mustang (Unit # unknown) - undergoing resto
    Just be careful about low rebuild estimates. A "GOOD" rebuild kit costs $350. Then there is the labor $200-$500, and that is if it does not need any other internal gears or hard parts not included in the rebuild kit. It can get out of control pretty quick. I've rebuilt T-5s that came from reputable shops that the guy spent $1400 getting it rebuilt. Customer could have spent a few hundred more and gotten a brand new T-5Z.
    Mar 2015
    Rose Hill,Kansas
    Was in same situation just different gear. Went t5z from jegs. 1750 brand new free shipping.
    Sep 2008
    HILLBILLY HOLLYWOOD, Tennesse
    Don't worry about the "Matching Numbers" VIN on the transmission case. Swap the tag and Re-Stamp the VIN on the replacement transmission if that's such a big deal.
    Corvette weenies have done that for YEARS!!!!
    www.musclecardeals.com
