Results 1 to 20 of 20
    Default Brake hose question
    So I'm swapping out my 8.8 in my 85, for another 8.8. I'm having some issues with mine, so I picked the other one ip so I can rebuild mine and have a spare..on to my questions. The rear brake hose on the 8.8 I'm removing does not use a banjo bolt, but it's set in a bracket and the hard line threads into it. The new rear has the typical aero banjo hose. I've been looking on like and can't find the hose I need. Anyone been through this..the pic is the hose I need. ThanksName:  20160628_223325.jpg
    The 1985 cars did not have the 8.8 rear end originally. They were all equipped with the 7.5" rear axle assembly from the factory.
    If the rear axle you are swapping out is an actual 8.8 then it was swapped in by a PO.
    The brake line you are looking at IIRC is the one year only 1985 center brake line due to the change to dual exhaust pipes on the 1985 5.0 models.
    It should look like this:
    Name:  85 rear brake hose.jpg
    That is available from Rock Auto under part number: WAGNER BH107278
    You can use that hose on your new 8.8 or you can update to the later model 86+ style rear center hose. Hope that helps.
    Thanks trey, I knew the rear had been swapped, just wasn't sure why I couldn't find a single bit of information on this hose. How would I upgrade to to 86 hose with the banjo bolt? I would have to change the hard line on the body? Or is there an adapter. Thanks again for the info!
    Jul 2010
    Houston (Clear Lake), Texas
    You can get that line at your local auto parts store...at least you can here in Houston. The original owner of my 1985 GT had swapped out the 7.5" with an 8.8" when the original 7.5" unit went south. I replaced all the soft brake lines on the car when I went through it. I originally picked up a hose/bracket for a 1985...they come from the auto parts as one piece...not realizing I should have ordered a hose/bracket for a 1986 car. The bracket is a different height for each and because they are made together, they do not interchange.
    HAD
    HAVE
    Quote Originally Posted by parkinglot View Post
    You would need the bracket that is riveted to the body from an 86-95 car. Then you will need the brake hose and rear end bracket for the 86+ 8.8 rear end. I haven't done this exact swap in years, so I don't remember all the details, but I believe it is fairly easy and straight forward. Good Luck!
    Last edited by wraithracing; 07-10-2016 at 08:01 AM. Reason: Schooled by Jack Once Again!
    I ordered the hose you posted trey, going to go that route right now, as I'm hoping to have this thing back together for saturday..lol..i'll keep you guys posted and I appreciate the info. I read about 30 posts the other night with no definitive answer, so I appreciate the time you guys took to help me out!
    Yeah, the banjo fitting hose is way more trouble than it's worth.
    So I got the hose..it doesn't fit the mounting bracket off my car, and one side has a bigger fitting than the other...this is becoming a headache..
    There are adapters for different line sizes. Also, you can get creative making a way to mount the hose to the bracket.
    You don't understand...I'm a truck driver, not a fabricator..lol...I modified the longer 8.8 bracket, as the person who swapped the 7.5 originally, left the short bracket on, just flopping around...I had ton use a drill..lol..I'm making progress...Name:  20160701_184644.jpg
    Oh, I'm not a fabricator either. I've just taken a chunk of metal, bent it in a vice until it does what I want, drilled some holes and done, haha. I would call what I do pulling solutions out of my ass.
    Haha, well...loops like I can almost add fabricator to my resume...almost!!
    Here's an example of my mad skills to solve the very problem you're having.
    If i remember correctly, i ended up going a different direction with it though.
    Trey,
    The chassis side bracket for a dual exhaust Mustang is only used on cars through 1995. In 1996, they all went to dual rear brake hoses.
    4 cyl cars don't use this bracket since they all have single exhaust and a 7.5".
    Jack Hidley
    Wow! I never noticed that even on my Cobra! Guess I didn't spend enough time underneath it!
    Thanks for the correction. I will correct my statement above.
    Thanks Jack!
    Bringing this back from the dead:
    What was the final solution here? And what did the OP do about the passenger side muffler hanger that just so happens to mount to the chassis holes already being used to hold the rear hard line bracket.....
    If it helps, I can post pics, but I believe most understand what I'm referring to.
    The dual exhaust brake hose bracket for the chassis is now available at the link below. You will also need to use a 1987-95 style rear center hose with it.
    https://lmr.com/item/LRS-2073BRKT/mu...-bracket-86-93
    Jack Hidley
    Thanks Jack. That was the original plan, but realized that I would have to pull and replace the entire hard line running the length of the undercarriage in order to meet this "newer" junction in the trans tunnel. I know it's pretty savage, but I believe I am just going to stack the factory hard line bracket on top of the muffler hanger and call it a day...... (and here comes your tech on why I shouldn't)
    Oct 2004
    Ann Arbor MI
    Just and another short piece of metal line with a union. Worked for me.
    Glad they are making the bracket. They where/are hard to find clean ones here in MI
    I would just do what Mr. Krazy did. Ideally you would bend the existing hard line at the rear seat bulkhead up into the driveshaft area so it is away from the muffler, then add on the coupler and new hard line. Then the line follows the factory 8.8" routing for the 1986-95 cars.
    Jack Hidley
