LTD Power Windows
The Passenger side power window had failed in the LTD, so I had an old one from a Mustang and it seems to work fine. It actually was a bit weak in the mustang, but seems to go up and down fine in the LTD, although it seems noisy. I did buy a kit to replace the plastic gear, cheap fix, half the time this is the only problem, also cleaned and greased the window track.
- You may not post replies
- You may not edit your posts
Forum Rules
