ok, so I have a 1986 mustang gt 5.0 5 speed with speed density. issue i have is car starts to idle rough then shuts off. i have replaced the ignition module with a oem motorcraft unit as well as tried 3 other ones that i have. all did not change symptom. i installed a new coil and a new mallory billet distributor. i replaced the ignition cylinder as well as ignition switch. i also replaced the connector at the module and properly soldered the connections and used heat shrink. i also replaced the connector on the coil and used solder/heat shrink. i have checked the ground for the computer up near the battery and it is fine. i have wiggled all the wires in the harnesses in the engine compartment and none cause any issues. i have confirmed that it is not a fuel pressure issue as i have a inline spark checker hooked up to one of the ignition wires and observed at times you can hear the engine miss (and see no spark in the spark checker when it's missing). I checked for codes and the only ones are 31 and 82 due to me not having those systems hooked up (i deleted them). also just before the engine is killed the spark shows intermittant flashing and then no flash right before shutting down. I have great fuel pressure as checked by my underhood guage and hear the fuel pump prime and run when it should. one thing i can tell is when the engine dies it will not restart if turning the ignition key to the start position from the run position, but if i turn the ignition key back to off then to crank it starts up right away (and then the same sequence starts again). I am at a loss here,. I tried grounding the computer body to a good ground using a jumper wire from the case to a ground point but this made no difference. I took a video of what is happening for more clarification. right now I'm thinking either a problem with the computer itself or maybe the eec relay?
you can use the link to view the video i took of the condition. thanks (sorry for sideways video)
PAY PARTICULAR ATTENTION AROUND THE 6 MINUTE MARK ON THE VIDEO TO SEE SOMETHING REALLY BIZARRE
https://youtu.be/6tL5EP-OF1I
