You can take the EEC-IV and distributor out of your car, and throw them off a cliff, and they wouldn't have
any effect on if a Fox Stang cranks.
Neither have *anything at all* to do with the starter engaging on a
Fox Stang.
A Fox Stang has zero anti-theft and prevent-starting-with-engine-running protection.
See the awesome diagrams that TMoss did:
http://www.veryuseful.com/mustang/te...itchWiring.gif
http://www.veryuseful.com/mustang/te...ng-ECC-EFI.gif
More files:
http://www.veryuseful.com/mustang/tech/engine/
Yea, I need to add thumbnails to the web pages. One of these days...
So....
1) Turn on the headlights.
2) Turn the ignition to on. Does the radio and wipers work? The radio and wipers should work.
3) With the headlights on, turn the ignition to "start". Do the headlights go out? Use a mirror, cardboard, what ever, to see if the headlights stay on, or go out. They should stay on.
4) Turn the ignition back to on. Do the radio and wipers still work? The radio and wipers should still work.
Sounds to me like you may have a bad battery or ground connection. The stock ground connection on a Fox was done because is was CHEAP! :-) Considering how many Foxes are left and only some had ground issues, it wasn't a "horrible" idea - it was just not a good idea.
Also, the starter solenoid may be bad, or the ignition switch may be bad.
Oh yea, you'd need another EEC-IV and distributor for the car to run, if you threw the old ones off a cliff. :-)
Good Luck!
