Low compression across two cylinders... 6 & 7. Every other cylinder was in the range of 120-140 psi. 6 & 7 were at 50-60 psi. Have not performed a wet compression test yet. Truck misfires noticeable at idle, but you cannot feel any difference while driving down the road even at highway speeds. Also pulls 19" hg of dead steady vacuum. Any guess as to what's causing my low compression & misfires? I was too lazy to perform a wet compression or leak down test today. Adjacent cylinders with equally low compression worries me to be honest. I get the feeling that this engine has never been apart before.
Truck is 1969 302 2bbl C4
