Results 1 to 14 of 14
    FEP Senior Member qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Default Dakota Digital Gauge Cluster
    Earlier this week I had a chance to install a new Dakota Digital cluster in my '85.
    I'll add some pics later of the install but right now I wanted to share a few shots of the view from behind the wheel. I'm pretty excited about it!
    The model I went with is the VHX Black Alloy with white LCD panels. I think it's a classic look, one that had I decided to go with run of the mill aftermarket gauges, would have been similar, but I think this is executed much better.
    The senders that came with it for speed, oil pressure and water temp looked and felt very high quality down to the Weatherpak connectors and shielded harnesses. They also included a billet plug for the speedo cable hole in the trans which I'll put in at some point later as I wound up using their (not included) magnetic pickup and 8 magnets on the driveshaft which gives about 16K pulses per mile. Plenty of resolution for me.
    There are also a ton of timing options (0-60. 1/4 mile, % fuel left, etc.) and other data that be displayed on the LCD's and icons on the gauge faces like high beam and brake, turn signals (through the factory bezel like I hooked up or on the gauge faces themselves), warning buzzers, trip odo's; all kinds of other cool stuff I don't know how to use yet. lol
    I'm happy so far. Everything works and seems accurate though my fuel sender in the tank seems a bit erratic so that will get replaced later down the line.
    I think I'm going to remove the red filters from the HVAC panel and set the radio lighting to match as it's variable. I also believe the clock has a red filter in front of the display so maybe that can light up white too. We'll see... I'm also going to try and figure out if I can make the idiot lights work again by making some sort of bulb holders as removing the OE cluster gets rid of the original mounting scheme for them.
    BTW, the "thing" you see in the left side of the images (with -.- on it in the last one), is a display for a collision avoidance system that uses a forward looking camera which does forward collision warning, lane departure warning and a few other features too. I used to work for that company and have had a system in this car (and one in my Lincoln) since then. Which by the way, has helped me to avoid one accident for sure when I got all confused at a goofy intersection (in an area I wasn't familar with... Ahem...) and lost focus of what traffic was doing in front of me. That thing went off, I almost pooped, and then I steered around the cars that had stopped in front of me. No doubt it kept me out of the body shop that day. Anyway...
    '85 GT
    The other one... 2016 F-150 XLT Supercab Ecoboosted with 3.73's...
    FEP Super Member escogt's Avatar
    Jan 2006
    Long Island, N.Y.
    That is so damn cool!!! I've been contemplating getting one of those kits myself for my '85GT. Thanks for sharing.
    How was the install?
    '85GT Bright Atlantic Blue
    '92LX Bimini Blue
    Jan 2010
    Rockledge, FL
    My pleasure! This style was hard to resist! Clean and to the point!
    I'll post some install pics once I get a few things tightened up but all in all for me, it wasn't that bad. Most all of the connections were made at the harnesses right behind the cluster but it was required to run the included wiring for the water temp and oil pressure sensors and of course swap them out too. That was cake though. For speed input one could use the included sensor but I chose to be different there and use a mag pickup so it added more work.
    The back of the OE/factory bezel does require some minor trimming to get things just right, and to be honest I put off doing all of it so I need to circle back to that. There is also the matter of wiring and mounting two or three switches depending on if you want to be able to dim the internal LCD's or not.
    If you're good with wires I'd say it will take a day or maybe a little longer if that's all you're doing. Of course, the EVTM and wiring diagram were most helpful to reference and without them you/the installer will struggle.
    Don't know if it's a "gotcha" with this set up, but my low fuel light in the info center is stuck on. However, it has always been on since I've had the car. It could be on now because the voltage regulator behind the cluster is gone (was removed with the cluster) but I'm not totally convinced of that. I need to dig more to see if I can make it work or not.
    A few other features having this cluster makes me want to add to the car are a retained accessory power circuit and an auto headlamp circuit. The headlamp feature is more "critical" for me because so far the few times I've driven it at night, I've shut off the car and the cluster turns off which makes we want to forget to turn off the headlamps. Adding those two circuits will make it feel like a new car especially if a dome light delay is also done. DD has a module that does all 3 but it's way pricey. I can do all of those things for less money but it won't be as neat and tidy, contained in one box.
    I'd say do it if you want bright, clear and accurate gauges with a clean look that provide some contemporary features.
    '85 GT
    That looks really good. The price and my inability to read a wiring diagram are the only things holding me back from one of those. But it would be great to have a set of accurate legible gauges behind the stock faceplate.
    1984.5 GT 5.0 5 Speed ANALOG
    BBK Long Tubes/H pipe/FM
    Edelbrock Intake/Holley 600
    8.8 w/FMS 3.73s
    Steeda Shifter
    2010 GT 5 Speed DIGITAL
    Track Pack
    Pypes Violator axle back
    Airaid Cold Air
    Jan 2010
    Rockledge, FL
    vxr500, FWIW I paid a lot less than the list price on the DD website for the kit. I'd be happy to hook you up (or anyone else for that matter) via PM with the retailer who sold it to me.
    Is the EVTM floating around for an '84? If so I think you could get where you need to go with it.
    '85 GT
    Looks awesome! I love DD. But not the price.
    Jan 2010
    Rockledge, FL
    Looks awesome!
    Thanks Brad!
    '85 GT
    Indeed it looks pretty cool. I will wait to get your opinion in a few months. My buddy installed their gauges for a classic Mustang a while back and after they sent him his third replacements and they died, he sent the whole show back and went back to the OEM 1967 gauges. Hopefully their quality control has improved a lot since then. It could've been just growing pains.
    Jan 2010
    Rockledge, FL
    Thanks! I'll be sure to let EVERYBODY know if I have issues down the road.
    IIRC I think I saw where you had mentioned this before, it almost made me shy away from them.
    '85 GT
    I'm pretty sure that the Low Fuel light operates independently of the Instrument Panel Voltage Regulator. I'm even more sure that there's a control module for the low fuel light, which can go bad. I know I switched the one out in my old '84, and got the light working again. I don't remember if the light was stuck on or off.
    I think the module was up above the glove box, but it's been well over 15 years...
    http://vb.foureyedpride.com/showthre...l=1#post224977
    Buck Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Jan 2010
    Rockledge, FL
    Great info guys! Thanks!
    '85 GT
    Jan 2006
    Long Island, N.Y.
    Any updates?
    '92LX Bimini Blue
    Jan 2010
    Rockledge, FL
    Nothing new... yet... Everything is still the same as it was when I posted. However, in December I bought the DD GPS speed sensor because I ran into issues with the way I did the mag pick up on the driveshaft. At some point here I'll get going on it again. My '90 is in my way, and frankly so am I... lol
    '85 GT
