Has anyone successfully bolted-in a non-dogboned 2.3 L replacement bellhousing for the SVO dogboned bellhousing? If so, year/PN?
Thank you.
Thank you.
My 4 Mustangs:
64.5 K Coupe
66 A fb
82 GT w/T-top
86 SVO
Yes. You need a bellhousing from a 2.3 with an RAD transmission.
What year range would the RAD trans/2.3 L combination be in? Might you have a bellhousing PN? And would the RAD throwout bearing arm work with the SVO clutch cable? Thanks
My 4 Mustangs:
64.5 K Coupe
66 A fb
82 GT w/T-top
86 SVO
I believe the bellhousing part number is D9ZC 6394 EA. I have one from my 79 PC that was originally a 2.3 Turbo.
I plan on doing the swap into my SVO, but I have not gotten there just yet. My plan is to use a stock 5.0 clutch cable. I am not sure on the clutch fork just yet.
Trey
Trey
The clutch fork that came with that bellhousing will work perfectly.
The RAD bell is compatible with the T5 trans. I've not yet been able to verify if the larger SVO clutch, flywheel, and starter is compatible with the RAD bell housing.
As luck would have it, I have a D9ZC 6394 EA for the swap....yahoo!!!! The main reason I am thinking of the swap is I've already had a dogbone break and my present back condition will not permit getting under the SVO to replace it if it decides to break in the future. Also, am I possibly correct that the clutching effort will be reduced with the swap....my left foot has some neuropathy problems. Thank you all!
My 4 Mustangs:
64.5 K Coupe
66 A fb
82 GT w/T-top
86 SVO
I can't test the bellhousing on my engine right now since it is sitting on the stand. But I did test fit my SVO flywheel into the D9ZC bellhousing and it fits just fine. Can't verify that there might not be an issue once installed on the engine, but the flywheel appears to fit without any issues. I believe the overall outer diameter of the flywheel is the same for the 79-86 2.3 (maybe even for the 87-93 too?) so it appears there shouldn't be any issues from what I can tell
Then again I have been wrong before!
Trey
Trey
I have a RAD flywheel, clutch, and TOB on my shelf, I suppose we could take measurements and compare them to someone's SVO parts?
I think the SVO clutch is 1" larger in diameter than the 79 2.3t disc? I'm unsure how that might effect relative clearances for the other SVO parts inside a RAD bell. I'm guessing it can be made to work with the right combination of OEM parts. I just haven't had a chance to mock it up yet.
Btw, I'm especially interested in this because I want to upgrade my 79 2.3t to a T5 trans with the larger SVO flywheel and clutch inside of the original RAD bell.
I am not saying that Rock Auto is the ultimate authority, but their catalog shows the same flywheel ring gear and diameter for both a 79 2.3T and an 86 SVO 2.3T.
It lists different clutch discs and pressure plates for the 4 speeds and the 5 speeds, but I believe it can be made to work. I don't have any of my 79 RAD parts other than the bellhousing but I do have all the parts from an 86 SVO for comparison if needed.
Trey
Trey
I only have the D9
....oops....
I only have the D9ZC bellhousing and my yet to be "re-belled", squeeky stock '86 SVO: I will be REALLY APPRECIATIVE with the measurements pointing to the D9ZC bellhousing and the '86 SVO flywheel, clutch, TOB & starter all working together w/o problems. Thanks ALL!
My 4 Mustangs:
64.5 K Coupe
66 A fb
82 GT w/T-top
86 SVO
Early 2.3 use 8.5" clutch disk, 11.256 ring gear.
Later 2.3 use 9.0" clutch disk, 11.256 ring gear.
Both early and later flywheels have to be of the same dia, since the ring gear is the same.
Later design with 9" clutch assys. Not that much difference in size.
Should fit fine in RAD bell.
The RAD bell starter mounting should allow the starter to spin a later design flywheel.
The flywheel machined faces are different between the two flywheels according to the pics.
Looks like wider face, multi bolt pattern on the later one for multi apps.
The larger 9" disc/pp prob wont even bolt up to the earlier 8.5" disc/pp flywheel due to the hole pattern (intentional?).
110.00 diff. Later version flywheel is lesser cost.
later flywheel says 21#
early flywheel says 22#
http://www.autozone.com/drivetrain/f...l-transmission
Rad trans/clutch disc and 2.3 T5 trans/clutch disk both 10 spline.
From here, appears certain later trans, flywheels and clutch assys interchange in RAD bells.
Dunno about SVO or quadrant adjust clutch cables, clutch fork, and stuff.
Final check is to do this 'live'. Who's first?
This is getting more interesting with all the entrys....! One unanswered aspect is the clutch pedal effort. I did replace the SVO quadrant when the oe quadrant failed and, at the same time, added a firewall adjuster all by Steeda: might that have added to the clutch pedal effort? All my previous Fox 5.0 clutches have had significantly less disengagement effort....
My 4 Mustangs:
64.5 K Coupe
66 A fb
82 GT w/T-top
86 SVO
I just made this swap in my SVO a couple months back. Bellhousing D9ZC 6394 DA with the clutch fork that came with it. Stock diameter flywheel and Spec stage 3+ 9" clutch which is the stock diameter SVO clutch. The 5.0 clutch cable fits perfect. Pedal effort does seem a little easier,but might be due to the new cable as well. There is another bell that is identical with a part number of D9BC 7515 BA. I had the two bells next to each other and made careful measurements of both. Including the clutch fork pivot ball and it's location. The two are identical.
86 SVO Boport stage 3 head,Turbonetics T-66,96lb/hr injectors,lots of BOOST!
Just a new cable can make a huge difference in the pedal effort. If that is really the only thing you hope to gain, I would throw a new cable at it. You really wouldn't think it would make that much difference but it truly CAN. Just depends on how bad the old one is.
John Adams
July 7, 1775
