Sorry I am drunk in case I mess this phone post up. I have been doing a carb conversion on my 1985 Mustang gt fiho and the tac doesn't work. What tells the tac where to be and how do I fix it? Thankz
Whether 4V or CFI, the tach takes it's signal from the 'ignition module side' of the ignition coil. But
if you're using a non-factory style ignition system, you may still need a tach adapter box.
Cheers,
Jeff Cook
What would you recommend for one of those? And what do they do?
I am running pertronix flamethrower 2 with matching coil. No box per say.
