Page 1 of 3 123 LastLast
Results 1 to 25 of 75
    Default Customized Sport Steering Wheel
    I bought a Ford factory sport steering for a Fairmont 15 years ago. Turns out it was not as nice as it looked on Ebay when it arrived home. The spokes had been spray bombed silver to cover the rust and original black color. The rubber grip was rough....worn and nicked.
    As disappointed as I was I held on to it, thinking I could fix it or resell it....I only paid $20 for it.
    Over the years I decided to try someday replace the grip with wood and restore the spokes.
    Well that time finally came.
    Here is what I started out with.
    Name:  steering1 - Copy.jpg
    I started by removing the grip
    Name:  steering3 - Copy.jpg
    Name:  steering4 - Copy.jpg
    Cut and glue some African Mahogany
    Name:  steering5 - Copy.jpg
    Next I started to machine the wood to fit both in shape and size. Needs to rap around the steel.
    Name:  steering6 - Copy.jpg
    Name:  steering7 - Copy.jpg
    Name:  steering8 - Copy.jpg
    Starting to look like it
    Name:  steering9 - Copy.jpg
    Before I went any farther, I need to restore the spokes.
    Brushed effect and all
    Name:  steering9.1 - Copy.jpg
    Now time to glue the wood to the wheel
    All sanded and stained. Dont worry....the color will lighten with the clear coat. The clear and the this type of wood will color change in different lighting like pearl paint finish.
    Finally, after hours of labor......
    Name:  steering13 - Copy.jpg
    Name:  steering14 - Copy.jpg
    Apr 2010
    Portland, Oregon
    Nice!
    The center cap had some help too
    Where the pencil is pointing is the damaged area.
    Name:  cap1 - Copy.jpg
    So I made skin to cover
    Name:  cap2 - Copy.jpg
    Here all back together and I added a little detail by coloring the fake allen heads
    Name:  cap3 - Copy.jpg
    Thank you
    It was a blast to do and would do it again.
    FEP Senior Member SVO4PWR2's Avatar
    Jun 2006
    Linden, NJ exit 136
    Out standing work
    -RICH-
    84 CAPRI RS FOR SALE
    i'm a car junkie - i love junkie cars
    Nov 2010
    Citrus Heights, CA
    Oh my God...
    That is so amazing! What a terrific mod!
    Bryan
    1983 Mustang GLX Convertible
    Mar 2013
    DENVER CO, the 303
    Wow great job!!!!
    That looks amazing!
    Matt
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    That's an awesome transformation! Great work!
    '85 GT
    Looks Great!
    I have a pair of steering wheels sitting in my garage if you are bored!
    Trey
    FEP Senior Member 86gtstang's Avatar
    Jan 2009
    Chester,SC
    Great job,looks great
    Robert
    86 GT vert
    85 GT
    FEP Power Member Fearnot's Avatar
    Concord NC
    Wow, that looks great! You do really nice work. Could we see a picture once you put it on the car?
    88 Turbo Coupe auto
    88 Turbo Coupe 5spd
    79 Fairmont Futura 4.6
    80 Capri 5.0/5spd project
    79 Pace Car 5.0/5spd project
    86 GT conv 5.0/5spd
    Really nice work! I'm not crazy about wood steering wheels but, what you did looks great. A really good use for a wheel that was otherwise not going to be used.
    Jess
    Previously owned;
    Turned out absolutely gorgeous! What did you use to make the final shape so nice and consistent?
    Dec 2006
    warner robins ga
    For years you have always done nice work.
    I had to buy mine.
    Yours is nice.
    Will Rogers" common sense is not as common as you think"
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Looks Great!
    Trey
    Quote Originally Posted by Stymees'mont View Post
    Agreeing with everyone that the mod looks fantastic!
    You have the dimensions and the tools, you could pump out a few extra now!
    Looks Great!
    Trey
    Sure...but it would be cheaper to buy an aftermarket steering wheel. Crazy how much time flies and how much wood is needed.
    Quote Originally Posted by Fearnot View Post
    If course I will post a pic with it installed. I couldn't tease everyone like that!
    Thanks Brad. Other then a router I really finalized the shape by hand. Sanding and carving then more sanding.
