Okay motor is in and running smoothly, carb is still going lean.The air fuel ratio is at 11.5-12.0 under WOT in 1st thru 3rd but as soon as your in 4th gear it goes lean to about 16 plus. Now the fuel pressure is at a constant 11-12 psi. Thru a 105 gph fuel pump. If I am just cruising in 4th gear and go to WOT it will pull for a second and go lean, only in 4th gear though. 1-3 are fine. Any advice? More jet, or more fuel pressure? At idle is at about 12.5 already so its a little rich and light cruise is at 11 to 12
