I would like to ask if someone could recommend a good lubricant for use on the distributor cam (breaker point ignition system). I've got an engine on which the point's rubbing block seems to wear out abnormally fast. There is supposedly a special distributor cam grease to prevent this (http://www.summitracing.com/int/part...6015/overview/) but I can't find this stuff available anywhere.
What should I use instead???
