I've got a sn95 lined up that I'm going to use for a 5 lug conversion. I have an 80 Capri with a 4cyl/4spd, the donor car has a 3.8 with a 5 speed. Would it possible or even make sense to use the transmission from the donor car with my 2.3? Is the input shaft the same? Can I use a 4cyl bell housing from a 5 spd trans with it?
Just came to mind the other day, I figure I would try to use as much as I can from the donor car.
