Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
  1. #26
    Oct 2004
    Ann Arbor MI
    I was told in the 90's to run this, and Not had any problems since I been using it. Read the last line. Oh ya it was hard using a GM product in a Mercury.
    PRODUCT # GM12345349 FEATURES
    Popular for High Performance Manual Transmissions
    Recommended for Tremec Transmissions
    Semi-Synthetic Base Helps Withstand Extreme Temperatures
    Helps to Ensure Smooth Shifts
    1 Quart Bottle - Sold Individually
    Superior Film Strength
    GM Performance Synchromesh transmission fluid is recommended for all Tremec brand manual transmissions. This Synchomesh transmission fluid will make your T-5 or T-45 transmission shift smoother. Synchromesh transmission fluid prevents the thinning effects of mechanical shear for stable viscosity superior film strength and excellent anti-wear performance.
    Application
    GM Synchromesh protects against rust keeps seals soft for long life and is compatible with brass synchros for smooth synchromesh shift quality. Consult your owners manual for the correct amount of bottles needed.
    Fitments Ford Mustang - Recommended for all Tremec brand manual transmissions, T-5 and T-45
  2. #27
    86caprirs
    Guest
    Wow lots of info. I do have some BG synchromech at work that I could use. I have a T56 in my cobra and I run Mobil 1 synthetic atf fluid. But I just want to run the proper stuff in my T5.
  3. #28
    So in my 84 svo i should go with ATF? needs to be changed.
  4. #29
    FEP Power Member 83gtstang's Avatar
    Shreveport LA
    I have to run that GM stuff in my T5z.
  5. #30
    New User
    Mar 2015
    Mechanicsville Maryland
    dexron/mercon fluid
  6. #31
    86caprirs
    Guest
    I pulled the T5 from the donor car and it has the red atf fluid in it. Fresh fluid too.
  7. #32
    I dumped cheap autozone brand atf in my 2001 t-5 when I did my swap. Felt and drove fine to me, but I haven't driven many other t-5 cars.
  8. #33
    OK guys, I'm in a particularly pedantic mood today, and... There is no "T" in Dexron. Never was.
    There. I feel much better now. Carry on.
    Cheers,
    Jeff Cook
  9. #34
    LMAO............thats great.
  10. #35
    Apr 2010
    Portland, Oregon
    "T5 Overdrive Manual Transmission" published by Ford Parts and Service Division, Training and Publications Department in December 1982 shows on the Specifications page:
    Lubricant
    Capacity: 2.4 Liters/5 Pints
    Type: DEXRON II
    Can't catch me!
  11. #36
    Dextcool antifreeze?
  12. #37
    LOL good one GG.
    Cheers,
    Jeff Cook
  13. #38
    Wellington, VA
    Blog Entries
    2
    now that's funny Jeff!!
    now we just need Mick to chime in with foxbody or fox body or ???? I hate spell check...
  14. #39
    It's neither.
    It's just "Fox". If you must have something more than that then it's the Fox platform, or "chassis".
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
